![Very Cool Parts](https://thefactoryfiveforum.com/attachment.php?attachmentid=40527&d=1428867450)
Power Steering Reservoir
I picked up one of FFR power steering reservoirs (I like to look of it).
It only comes with one mounting bracket. I would like to mount w/ two if possible.
Anyone know the manufacture of this set-up and/or have seen a comparable mounting bracket ?
I believe the OD is 2.3" but will need to confirm.
Mk4 #9165, Base Kit with lots of options, Delivery on 08/17/2017, Coyote, TKO600, 2015 IRS, 18" Halibrands, 12.99" Wilwoods
![Cool](images/smilies/cool.png)
may be able to just call FFR and have them send another for a couple bucks . . .
thought that/tried that. No dice
Here is what I suggest for a start. Put this, "2.25" overflow tank mounting bracket" or some variant into google and select images. Then you can see what is out there in the world. You could find exactly what you need but listed for a completely different use.
Poking around myself, I found this: 2.19" coil mount bracket.
https://www.speedwaymotors.com/EMPI-...unt,82849.html
I did some searching to. I'll take a deeper look. FFR say is 2.3" OD, I measure 2.375".
Thanks for the lead ...
![Breeze](https://thefactoryfiveforum.com/attachment.php?attachmentid=40534&d=1428868052)
