Results 1 to 5 of 5
Thread: Fitting size?
    Mar 2017
    Norway / Merritt Island FL
    Fitting size?
    What fitting can I use between 3/8" female on the Trick Flow fuel filter and the 1/2" -20 (?) male on the FF supplied Fuel line?
    My metric mind does not think straight
    Sigurd
    Type 65 Gen 3, 347 Fi, Tremec, IRS, Wilwood, AC, PS
    Mar 2017
    Think I found one:
    https://www.summitracing.com/parts/sum-220668b
    Btw, where do I flare with 45 deg, (brakes ?) and 37 deg (-AN ?)?
    Sigurd
    Senior Member Alphamacaroon's Avatar
    Jan 2019
    Richland, WA
    AFAIK the only thing that uses 37° flares are the AN fittings. Everything else is 45°, but there are different types of 45° flares (single, double, bubble, etc).
    Colorado Springs
    Quote Originally Posted by Sigurd View Post
    Standard SAE fitting use 45*. Brake fittings should be double 45* flares. As said, 37* is for AN fittings, and some home plumbing fittings.
    Also, keep in mind that the fitting you're looking at requires an O-ring, sold separately.
    .boB "Iron Man"
    www.RacingTheExocet.com
    Jan 2019
    Richland, WA
    Quote Originally Posted by Bob Cowan View Post
    Does that require an o-ring? It does look a little like a -6AN to -6ORB (which requires an o-ring), but the one OP linked to is a -6AN to 1/2"-20 inverted flare fitting (which doesn't require an o-ring), right?
    @Sigurd, if I'm understanding right, I think you can just use standard NPT fittings (no need for AN fittings). You probably just need a 1/2" NPT to 3/8" NPT adapter (which you can probably pick up at Home Depot).
    Edit:
    After looking at the manual I think you'll want a 1/2"-20 inverted flare (assuming that's the one you have attached to the fuel line) to 3/8 NPT adapter. That one might be hard to find at Home Depot. I didn't see one on Summit, but you might be able to find one somewhere. I think the key here is that you don't really need an AN fitting anywhere in this mix (unless you want to switch to AN). The Trickflow filter (which I have as well) is all NPT and the other end of that fitting you linked to earlier (-6AN) at Summit will not fit into the Trickflow filter. If you did want to use that part, then you'll need to add a 6AN female coupler, plus a 6an to 3/8 NPT male adapter.
