Getting down to final details so I thought I would install whatever was needed to close off the hole where the horn button and kit goes. I contacted factory five an purchased the piece that holds the FFR logo. Looked easy, as if I should be able to just press it in but nooooo. The o ringed bottom is much smaller diameter than the inner opening of the wheel. I am figuring there is something else that possible screws on with the nut and sticks upheld by the o ring to insulate it from contact with the outer wheel. Can someone show me a picture of the parts I need?
