Thread: For Sale: FFMetal Battery Box
    Senior Member Jim Doak's Avatar
    Midway, Utah
    I’ve got an FFMetal battery box for sale that I bought several years ago. The box has been opened but that’s all, the aluminum components are still in their original wrapping paper. $120 including shipping within the U.S.
    Sold September 2019: 46.5K-mile Mk 1 with a Blueprint 347, Sniper EFI, 3-Link with VPM Rear Sway Bar, Power Steering with Hydroboost Brakes, Under Car Exhaust, Rear Fender Flares
    Received July 2024: MK4 complete kit with IRS and 15" wheels
    FF6602's Avatar
    Nov 2018
    State College, PA
    Hi Jim,
    I have a Mk 3.1 that I bought partially-finished. Do you know: a.) will this box fit in a 3.1? and b.) how hard do you think it will be to install given the fact that the trunk floor is already in place on my car?
    Thanks!
    Craig
    10/2018 -- acquired Mk3.1 #6602 which was an unfinished project in go-kart stage; 9/2019 -- completed car enough to drive locally and compete in autocross events; still in original black gel-coat; 347 Stroker w/ Holley 650 carb, roller cam; Tremec 3550; 3.51 rear diff; lots of Breeze pieces; 2021 -- XP Champion in Central PA Region - SCCA Autocross Series; 2022 - installed windshield and registered in PA; my Build Thread -- https://thefactoryfiveforum.com/show...ished-Business
    6/2022 -- acquired Mk3 #1004; finished build; 347 stroker w/ Holley 560 carb SOLD
    Midway, Utah
    Quote Originally Posted by FF6602 View Post
    Hi Jim,
    Thanks!
    Craig,
    a.) I'm pretty sure it'll fit your Mark 3.1., b.) I think you can install it with the trunk floor aluminum installed (see the first link I'm attaching); however, I wouldn't try installing it if your body is already mounted to the chassis. I've also attached a link to the installation instructions.
    https://www.ffcars.com/forums/17-fac...leted-mki.html
    https://www.ffmetal.com/batteryboxinstructionsMK4.html
    FF6602's Avatar
    Nov 2018
    State College, PA
    Thanks Jim. The body is off the chassis right now. I'll take a look under the car tomorrow and compare that to the install instructions but I feel pretty confident I can make it work. Will get back to you soon.
    Craig
    BTHWarrior's Avatar
    Feb 2017
    Lewisville, TX
    Do you still have this available?
    Mk4 Roadster #9054, 2001 Mustang GT donor, 4.6 SOHC engine, automatic transmission, ABS brakes
    Midway, Utah
    Battery box has been sold.
