Results 1 to 2 of 2
Thread: UCA Rear Nut Spacing
    Senior Member D02G's Avatar
    Mar 2019
    CT
    There’s no space to hold the upper control arm rear nut to tighten the bolt. Is there a trick?
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    IIRC, I used an open-ended wrench held almost perpendicular to the nut from the back. Not ideal, but it gave me enough leverage to be able to keep the nut from spinning while I torqued the bolt.
