Results 1 to 3 of 3
Thread: 840 HP Dodge Demon vs 1000 HP Hennessey ZR1 Corvette Roll Racing
    This will get the blood flowing!
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
  2. Thanks GoDadGo thanked for this post
    Likes GoDadGo liked this post
    Chino Valley, Arizona
    Wow!! Brutal...
    Ok, got to note...
    You can't put 1000hp on the ground *with street tires* any better than you can put 850hp to the ground *with street tires*.
    Much less with xxxxlbs on the 1000hp Corvette, or xxxxlbs on the Demon.
    Name a *street* tire (and turn off launch control + traction control).
    And go try it at 500hp/500'lbs in a 2000-2300# *Cobra* replica...
    You can do the same thing with 400/400 (maybe less).
