Results 1 to 15 of 15
Thread: Serpent Express Storage
    Burlington, WI
    Wondering if many store their Serpent Express trailers only indoors. I am looking for self storage facilities but one to house a trailer of this size are a bit pricey.
    Do many of you let them sit out.
    Road Legal August 31, 2017
    I've been leaving mine out for the last couple years. For the first few years of its life we rented indoor storage. But you're right, it's crazy expensive. Now that we've moved and don't need the storage space, plus no neighborhood covenants to deal with, I have it parked outside in the side yard. I did put a tarp over it last winter, but didn't this year. Just lazy I guess. I suspect in the long run the soft top will deteriorate more quickly with it outside vs. inside. How much, I don't know. But those storage costs add up really fast and I figure I can get a new soft top at some point if necessary.
    Burlington, WI
    [QUOTE=edwardb;368310]I've been leaving mine out for the last couple years. For the first few years of its life we rented indoor storage. But you're right, it's crazy expensive. Now that we've moved and don't need the storage space, plus no neighborhood covenants to deal with, I have it parked outside in the side yard. I did put a tarp over it last winter, but didn't this year. Just lazy I guess. I suspect in the long run the soft top will deteriorate more quickly with it outside vs. inside. How much, I don't know. But those storage costs add up really fast and I figure I can get a new soft top at
    Thank you very much. I just returned from attempting to back into a 10 by 22 rental facility and came to my senses. Tight would not have adequately described how tight it would have been. Their unit that would work is $195 monthly. I do have the yard space.
    [QUOTE=ThickCobra;368314]
    Mine always sets outside. I have thought of buying a camper cover and using that, they aren't very expensive. At $195 a month storage you could buy a very good cover and pay it back quickly. This one is less that a months rent.
    https://www.etrailer.com/RV-Covers/Adco/290-52238.html
    Jay,
    At our County Fairgrounds as well as several surrounding counties they offer Boat, RV, trailer, etc. winter storage inside the livestock barns from October to April for a flat rate of <$250. Might be worth a phone call.
  6. Thanks WIS89 thanked for this post
    Burlington, WI
    Jay,
    Jeff,
    Great idea, I'll will look into that. Though I could park it in my yard, I'd rather not. A friend of mine rents a spot in a secured but not covered lot, so I'll be looking into that possibility.
    Jay
    Creedmoor, Texas
    I store my 16' SE outside covered with a Harbor Freight tarp for $59. It will last for a year or so depending on the wind.
    Texas Cobra Club-Austin
    Burlington, WI
    Quote Originally Posted by seagull81 View Post
    Great idea. Could you share the part number of the tarp.
  10. #9
    Quote Originally Posted by ThickCobra View Post
    I furnished a link to an RV cover that should just slip right on.
  11. #10
    Creedmoor, Texas
  12. #11
    Keeping it covered is the way to go. A small RV cover will last 3-4 seasons and then the HB tarps will last one. 10 years ago those plastic tarps would make it 2-3 years but these days they all go to shiza in short time....if you get the "extra heavy duty" you get to pay more for the same result ...da Bat
  13. #12
    I use one of these to cover one of those garage sized tents in my yard. I cover the tent in order to extend the life of the cover material. I figure that keeping the UV rays off the tent, it will hold up longer. I replace the tarp every other year or so, and have been pleased with how the tent has held up.
    Those tarps go on sale frequently for $39.00; that's when I grab one. Good luck with whatever you decide. I just wanted to share my experience in hopes that it might help you with your decision.
    Burlington, WI
    Much appreciated as I believe I've located a very inexpensive locked lot to store the trailer. I will absolutely cover it.
    Jay
  15. #14
    On a roll Al_C's Avatar
    Wheaton, IL
    I bet you could find a hangar at a local airport to store it in
  16. #15
    Burlington, WI
    That's very funny. You obviously know Chris well.
