Thread: Need to drill pickup tubes for EFI in tank pump?
    Mar 2018
    Getting ready to install pump inside tank. FFR instructions are for in-line pumps and they show drilling out the end of the pickup lines. The FFR instructions for in-tank fuel pump do not say anything about the pick ups. What do you guys think? Do I need to drill out the pickup ends?
    MK IV Roadster-Delivered Nov '18
    Complete Kit, Gen2 Coyote, TKO 600, 2015 IRS, FFR brakes, FFR power steering, Full length headers
    Southern WV
    I just installed the pump with no changes to the tank
    Rick
    Senior Member D02G's Avatar
    Mar 2019
    CT
    Quote Originally Posted by Brian76 View Post
    I have the same question.
  4. Thanks JimLev thanked for this post
    Placitas, NM
    Page 260 in my '33 manual says to start with a 1/4" drill then increase the drill size to 9/32 or 19/64 to open up the end.
    May 2018
    I called FFR about this when I was at this step. They said it was not necessary to drill out the tubes on the EFI pickup.
    Mar 2018
    Thanks for the responses. If FFR claims its not necessary that's good enough for me. Thanks for saving me a step chjort. Not sure why the in-line pump requires it and the in tank does not. I also noticed that the supply pipe for the in-line pickup tube assembly is larger diameter than the EFI in tank pick up pipe.
    Richard Oben's Avatar
    Kansas City MO
    The ends were very crimped on the last one we did. We opened them up the make the lines their full size. Not enough to eliminate the taper, quick fittings still work fine, but enough to make sure it wasn't a restriction. JMHO.
