Results 1 to 3 of 3
Thread: Bushings. Poly or OEM Rubber?
    Mar 2019
    Like the title says. What bushings are you guys using? how's the ride? I'm looking to build a street/track car. Thanks in advance for your help.
    May 2019
    ocean springs, ms
    Quote Originally Posted by davidstrother View Post
    I think if you are going to track the car, harder than the OEM stockers is a requirement. Anything that makes the can slower to respond to input on a track is in my experience - no help at all. The readily available and quite possibly cheaper option would be the poly bushings. If you don't mind some periodic maintenance there I personally don't see a down side. Not quite as sharp but lower in maintenance might be the Group N OEM higher durometer rubber bushings. And by maintenance I mean periodic refreshing of lubricant on the poly bushings to stave off insanity inducing squeaks.
    My .02
    ss
  3. Thanks Kiwi Dave thanked for this post
    Mar 2019
    Thanks bro, I'm sure I'll do the Poly's. I was just concerned about ride quality on the street. I've never had Poly bushings on anything.
