![Very Cool Parts](https://thefactoryfiveforum.com/attachment.php?attachmentid=40527&d=1428867450)
Electrical Help
Need some troubleshooting advice.
Mk4 coyote and ron francis wiring.
Been driving for 1500 miles / about 1 yr.
I have lost power to my horn and cooling fan fuses. the other 2 fuses supplied HAAT from the battery are still powered. (I pulled the fuses and got 0 V on either side of the female fuse receptacle or whatever it is called in the fuse panel)
The engine runs (right up until i get scared it is getting hot w no fan running. ) lights works, etc. Just lost those 2 fuse locations.
Any thoughts other than a defect / break in the actual fuse panel?
TIA
Greg
If you're using the FFR ignition switch, check the ACC. stud of the switch. Sounds like you're getting power to flow through the IGN. side of the switch but the ACC. side has given up the ghost.
![Stewart Transport](https://thefactoryfiveforum.com/attachment.php?attachmentid=40533&d=1428868052)
