Thanks Thanks:  2
Likes Likes:  9
Results 1 to 10 of 10
Thread: Suggested tools?
    Feb 2019
    Oshawa, Ontario, Canada
    Suggested tools?
    I am still in the planning stages and will likely be ordering my kit for pick up next spring. I have all the usual hand tools. I was wondering if any of the experienced builders could let me know about any tools that they think made life easier and would be beneficial to pick up prior to building? This post was inspired by rsw81's post about bench grinder vs bench sander.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
  3. Thanks Drezx6r thanked for this post
    Likes Drezx6r liked this post
    Seasoned Citizen NAZ's Avatar
    Two most important pieces of equipment are a good radio to blast your favorite tunes and a refrigerator full of adult beverages.
  5. Likes Papa, SSNK4US, Drezx6r liked this post
  6. #4
    Band-Aids are good to have handy..
    Been more than one build, christened in blood. As proof, I have a nice scar in the shape of a "C", (for Cobra?), on the back of my right hand...
  7. Likes Drezx6r liked this post
  8. #5
    Placitas, NM
    +1 on the above. An AC to keep the garage below 80º F would be nice, some heat in the winter.
    Also a belt sander for setting the door, hood, trunk gaps.
  9. Likes Drezx6r liked this post
  10. #6
    Feb 2019
    I guess I'm not to good with the search function on here as I tried a few searches and didn't come up with what you provided. Thank you
  11. #7
    Quote Originally Posted by Drezx6r View Post
    Not a problem at all. I just wanted to give you the benefit of the previous discussions. The search tools on the forum are not exactly the best I've seen, but the advanced search works well and in a pinch, use Google and search "Factory Five Forum <+ your key words>"; example: Factory Five Forum Tools
    You'll get descent results that way in most cases.
    Legal: 1/30/2020
  12. Thanks Drezx6r thanked for this post
  13. #8
    Senior Member TDSapp's Avatar
    Frisco, TX
    Another choice versus the radio... I have a 50" HD TV with a Firestick plugged into it and a sound bar. It is however setting on top of the refrigerator that is full of adult beverages.
    Quote Originally Posted by AC Bill View Post
    Baind-aids... Phfff Real men use paper towels and electrical tape. (SWMBO got tired of buying me Band-aids.)
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
  14. Likes Drezx6r liked this post
  15. #9
    Tim, I like your style. A TV would be a great addition on those weekends when NHRA is on.
  16. #10
    mburger's Avatar
    Punta Gorda FL
    For searching try Googling site:thefactoryfiveforum.com tools
    Use that format for any search word.
    site:thefactoryfiveforum.com <search word>
    Mark
  17. Likes Drezx6r liked this post
