Results 1 to 5 of 5
Thread: VIn #
    herb fraser's Avatar
    VIn #
    Does anyone know where the VIN is stamped into the frame on the 35?
    Thanks herb
    To the left of the steering column on the frame.
    Your the best, I knew I could count on you !
    Thanks Herb
    Super Moderator
    Ray's Avatar
    La Mesa, California
    Technically that’s not a VIN since FFR isn’t a vehicle manufacturer. If you get lucky your inspector will use that number as the VIN rather then assigning a different number.
    Ray
    Nov 2018
    Chandler, AZ
    Arizona assigns a different number.
    Factory Five Racing Roadster MKIV -- #9196 -- 347ci, 475 HP, 5 Speed, Plymouth Prowler Orange Metallic
