Results 1 to 5 of 5
Thread: VIn #
    herb fraser's Avatar
    VIn #
    Does anyone know where the VIN is stamped into the frame on the 35?
    Thanks herb
    wallace18's Avatar
    Trenton, Florida
    To the left of the steering column on the frame.
    Your the best, I knew I could count on you !
    Thanks Herb
    Super Moderator
    Ray's Avatar
    La Mesa, California
    Technically that’s not a VIN since FFR isn’t a vehicle manufacturer. If you get lucky your inspector will use that number as the VIN rather then assigning a different number.
    Ray
    Nov 2018
    Chandler, AZ
    Arizona assigns a different number.
    Factory Five Racing Roadster MKIV -- #9196 -- 347ci, 475 HP, 5 Speed, Plymouth Prowler Orange Metallic
