Does anyone know where the VIN is stamped into the frame on the 35?
Thanks herb
Thanks herb
Your the best, I knew I could count on you !
Thanks Herb
Technically that’s not a VIN since FFR isn’t a vehicle manufacturer. If you get lucky your inspector will use that number as the VIN rather then assigning a different number.
Ray
Arizona assigns a different number.
Factory Five Racing Roadster MKIV -- #9196 -- 347ci, 475 HP, 5 Speed, Plymouth Prowler Orange Metallic
