Results 1 to 5 of 5
Thread: Balancing Goodyear Billboards
    Senior Member tonywy's Avatar
    Nanticoke, Pa
    Does anybody know the best method to balance these tires ?
    Maricopa AZ
    Static balance with stick on weight. Be careful with placement so they don't hit the calipers.
    Jax Beach, FL
    Why static? Just curious.
    Lost Wages, Nevada
    Billboards, because of their soft sidewalls, tend to flex a lot at speed (picture dragster tires at launch, only not near as bad). Best way to balance a tire with those characteristics is to set it on a bubble and go for the best you can get. If you feel adventurous, have them "Road-Force" balanced to verify your bubble weight placement. This has always worked for people that I know that race with Billboards . . .
    Doc
    Seasoned Citizen NAZ's Avatar
    Never dealt with Billboards but what Doc describes certainly does apply to bias ply wrinkle wall drag slicks. I have to bubble balance mine and it works just fine. My DOT radial drag slicks can be balanced like your car if I could find a machine more than 16" wide so I end up bubble balancing them as well on my cheap bubble machine with stick on weights from HF.
