Results 1 to 3 of 3
Thread: An answer for after market CV joint separation
    Mar 2019
    I was having the same trouble as many others, replaced front C/V joint/axle shafts, on my donor. Mine happened to be NAPA axles. I spent quite some time with my BFH (Big $%&#@!* Hammer) working on one of them. I believe I found an easier way.
    Thanks to my buddy Jay. He's the handsome yet camera shy person at the controls of this adventure.
  2. Likes AZPete liked this post
    Quote Originally Posted by davidstrother View Post
    pipe trick
    Fenton MI
    Pipe didn't work on my one aftermarket axle as the clips are different and thus will not separate in the same manner. I ended up replacing it with an OEM axle after dismantling both I felt that they're superior in quality.
    Factory Five 818c #456
