Results 1 to 3 of 3
Thread: rear end lower control arms misaligned
    Jan 2019
    just went to install the rear end and it appears something is off. i suspect one of the brackets is mis-fabricated. has anyone run into a similar issue? am i overlooking something?image1.jpegimage2.jpgimage3.jpgimage4.jpgimage5.jpgimage6.jpgimage7.jpgimage8.jpeg
    Norton, MA USA earth
    Everything looks ok to me Try shifting the whole rear until you can get the lower control arm in. The panhard bar will keep it centered.
    Jan 2019
    so after a little maneuvering i got them. ended up rotating the rear end while pushing the control arm over and malleting it in. put the upper control arms on loosely then jacked it up to get the shocks in. seemed way too difficult for all new fabricated components
