A few months ago i saw an aluminum filler to fit between bottom of the dash and tranny hump, i cant find it now, does anybody know who was selling them?
Walt
Walt
FFR8237 Donor build 89 GT , MK 4 , T5 , 17 " hallibrands 9" front 10.5 rear ,4×4 headers stainless mufflers, dual chrome roll bars, coil overs all 4,A/C and heater , soft top, 3:55 gears.
Whitby Motor Cars sells them. They are 3 pieces of aluminium with bent edges to rivet together. There is enough spare alloy in your kit to make one from scratch if you want too.
Mine has a radio, 2X6" speakers in the sides, pull handles for footbox ventilation & switches for the inline fans in the vent tubes. The console also supports the dash so I don't need to put screws in the upper face of the dash.
Kevin
MKIV #8234
I think I may have the pattern for that if you want to bend one up for yourself.
Ray
I made my own from aluminum sheet. I prefer a more upright console and built it so that it is set back under the edge of the dash a bit.
MKIV Complete Kit: 3-link, vintage gauges, glove-box dash, chrome roll bars, 17" wheels, B/T leather seats, Gas-N side pipes and headers; Drive train: Levy 408w w/carb, TKO600, Moser 8.8 with 3.55s and GT rear brakes; Paint: Jeff Miller Ford Magnetic Grey Metallic with BMW Titan Silver stripes
Ordered: 4/5/16, Order completion: 5/14/16, Delivered: 5/24/16, First start: 6/22/19, Registered and legal: 10/28/19
Here is mine. Started with cardboard, making an aluminum version this weekend.
Factory Five Racing Roadster MKIV -- #9196 -- 347ci, 475 HP, 5 Speed, Plymouth Prowler Orange Metallic
I’ve never seen an elbow console like that. I’ll have to mock one up and try it.
[QUOTE=GWL;373143]I copied sjDave's concole and like the way it fits and looks. It can also support the lower part of the dash if needed. I do have the pattern somewhere, PM me if desired. I mocked it up in a light cardboard first.
Hey George, glad you were able to build one off the template and are happy with the result. If anyone else wants a template PM me with your Email Address. Here's some pics of the finished console like Georges in my car. I did attach another strip of aluminum to the bottom flange of the Dash with RivNuts that the console screws into and two hinged lower dash panels either side that have courtesy lights in them.
Boy everybodys looks great, Ray i sent a pm with my email. Thanks to all the responses, gives even more ideas.
Walt
I designed a narrower console that aligns with the gauges with mirror finished stainless for the faceplate.
I bought one from Whitby
https://www.whitbymotorcars.com/product/center-console/
I notched the underdash filler I got from Mike Everson (Replica Parts) so it would slide up - it doesn't support the dash.
Probably could make one that fits better. In hindsight, I probably would, but if you don't want to make one, Whitby's is an option.
CONSOLE 4 FLAT - FULL SIZE.PDFCONSOLE 4.PDF
These are the plans I have for making a center console that fits under the dash. Hope these help.
Ray
Thanks Ray
Ray,
I'm trying to figure out how to add a pdf. How did you do it?
George
SJDave, where did you find the material to match the dash, and does the hump cover just cover the carpet?
Walt
Hey Walt,
The padded Vinyl was ordered from Factory Five as a bulk Roll, so it matches their dash material perfectly. Don't know if they still list it in the product offerings, this was 2010 when I bought it, maybe call them.
Yes, the carpet comes over the top edge about 2". I installed (6) 1/4 x 20 Rivnuts in the top of the tranny structure. I needed 1" thick plywood so that my cup holders would clear the top of the TKO 500 tranny, I cut the bent sides off the FFR supplied tranny cover aluminum and used some adhesive and some wood screws to laminate it to the bottom surface of the marine plywood (fire protection). I made some Black Nylon washers and used some Stainless thin head allen bolts from McMaster Carr to attach both the tranny cover, the console, the under dash panels and the Dash itself. I like the functional look. It's sure nice being able to pull the tranny cover for working on the car down the road.
Got mine at a place called "Mill Outlet Village" in Raleigh. Might be part of a chain.
Kevin
MKIV #8234
This is my console. Did mock up out of cardboard to get shape then fabricated out of 1/8" alum & laminated with Sapele wood and carbon fibre sheet.Console.jpg
Very nice!!
Finished mine today.
Cupholdersplus.com sells one that makes a nice armrest. It's called the drinkster narrow bench seat console. Worked for me. Had to cut the back side of the console to fit tight against the rear bulkhead wall of the cockpit. Not a major issue. It's plywood wrapped in leather. Shifter boot ring clears the front if the console by 1/2 inch. Added bonus is a little bit of storage area in the console for smaller items.
JRL16
Why not do it in carbon Fiber....
Mark IV base kit, 2015 Coyote, Wilwood brakes, IRS-3.55 TruTrac, T56, ABS, PS, Nitto G2, Carbon fiber Dash
