Results 1 to 6 of 6
Thread: 351W Running Hot
    Atlanta, GA
    351W Running Hot
    Hello Roadsters,
    I have a Mark IV Roadster with a 351W at 400 HP. I have been running too hot to drive. I am at 220 before getting out of my neighborhood. Here is what I have fixed/changed since:
    1. Fluid
    2. Thermostat (180) i tried a 160 as well
    3. Radiator Cap
    4. Water Pump
    I am suspecting a radiator. I have the FFR supplied radiator approximately 6 years old. I've had the car on the road for 5 years with no overhead issues.
    Potential Causes:
    1. Need to burp the expansion tank
    2. Clogged Radiator
    Thoughts:
    1. Swap out the current radiator for an aluminum bigger core radiator.
    2. Remove the "F" panel square expansion tank and go to a straight tube set up.
    Help Please.
    Sam,
    Ohio
    I think it’s important to address the air direction into and out of the radiator. Try to make sure all the air coming into the grill opening is going into the radiator. Plenty of vendors out there with good components to help. Mike Everton sells a nice piece for the grill opening area and Breeze has a piece that fills the gap from the top of the radiator to the body. I made panels to fit on the side of the radiator to protect it in the wheel openings. Can’t emphasize enough the importance of a shroud to attach the fan to. Make sure the fan works properly. Mine comes on at 180-190. It’s thermostatically controlled by a sensor screwed into the engine near the thermostat and has an override switch on the dash. As yet have never had an issue. The round overflow tank was undersized for my motor. Empty when cold full when warmed up. Got a larger square unit from Canton Racing with a sight tube attached. No guessing fluid level anymore. Good luck.
    JRL16
    Mar 2018
    Maryland
    Is this problem all the sudden?
    220 before going out of your neighborhood?
    You temp should barely reach 185F, unless your neighborhood is really big.
    I'm thinking air bubble in your coolant system in the engine, try to bleed everything before swapping expensive part.
    Senior Member frankb's Avatar
    Feb 2014
    Marana, AZ
    How long has this problem been happening? You say your build is 6 yrs old. Is that build time, or is there some driving time in there without this issue? If this issue has been going on since you started driving, I suspect that there is air trapped in your cooling system as Francky suggested above. There have been several threads on this forum suggesting that the front of these cars need to be elevated to get all the air out of the cooling system when first filling.
    Seasoned Citizen NAZ's Avatar
    Are you referring only to the gauge when determining 220 is too hot? Are there other signs that you are running hot?
    The first thing a good technician does is to verify the complaint. In this case, verify that your 220-degree reading is accurate before throwing parts at the problem.
  6. Likes brewha liked this post
    Lilburn, GA
    Sam, try warming the car up, shutting it off, and CAREFULLY touching the radiator ALL OVER. See if it's the same temp all over. If you find cool spots, it needs replaced, or it could be rodded out.
    FYI... Was nice meeting you on Sunday at the car show.
    Ducky aka David
