Results 1 to 19 of 19
Thread: Engine emblems / badges over the side vents
    On a roll Al_C's Avatar
    Wheaton, IL
    I’m looking at options for engine emblems/badges for over the side vents on the roadster. I know this topic has been discussed before, and I checked all the links in one of those threads. What I want is something that says “Coyote”. What I’ve found:
    - ********** (no longer a vendor?) has “powered by Ford” and “427”, but nothing coyote.
    - Wareaglescott has a nice one from Billet Badges, but they’re pricey.
    - American Muscle has “5.0”, but no coyote.
    - Amazon has one here: https://www.amazon.com/dp/B007J34KXY...v_ov_lig_dp_it
    - Nothing at Summit or Jegs
    Got any other ideas on emblem options / sources? I like Scott’s, but maybe I can save a few bucks…
    Nov 2015
    Elverta, CA
    Look at local laser engraving business. There are many small time home based folks doing this work. A custom badge would really separate your car from the field. You also could try local high and college's for one with a trades program that could cast one for you. Good luck.
    Nov 2012
    Tacoma, WA
    I got my emblems on ebay they have a lot of different Coyote options and powered by Ford options also. I personally put the powered by Ford ones that are raised. Here is a link to some nice ones on ebay that I almost put on mine, but decide to go with the classic/ modern look of powered by Ford.
    https://www.ebay.com/itm/2pcs-ABS-Ch...sAAOSw3k9cj1nR
  4. Thanks rrbardsley thanked for this post
    Jun 2018
    North Vancouver, BC, Canada
    Gen 1 '33 Hot Rod #1104
  6. Likes Boydster liked this post
  7. #5
    May 2019
    I was actually thinking of having my cousin 3d print some badges for my car. Lucky for me that he excels in the area and he already has the recourses to do it, however, I have herd that many libraries are buying 3d printers with software that is user friendly. I already asked about them a little and he said that it sounded like a great use for a 3d printer and like it would only be a few dollars in materials per badge. You could make your own badge the exact size you want and customize it any way you want. I was figuring I would "contract" my cousin to some up with something unique for the steering wheel badge and something for in the engine bay. Thought about doing a small "Built by" with my signature badge and putting it on the dash but have kind of gone away from that.
    Anyways, if you want a specific size, it is easier then ever to have one made with a 3d printer for cheap. I think there are also companies you can send your design to who will print it and mail it to you if you don't have access to a printer through your library or friends.
  8. #6
    Raleigh NC, OIB NC
    Have a set of these on my fuel rail covers.
    Took a lighter approach outside
    Kevin
    MKIV #8234
  9. #7
  10. #8
    Wheaton, IL
    Thanks, everyone! Here's what I'm getting:
    I am buying two from 2bking. He ordered some extras when he had them made initially.
  11. #9
    Member Dewey McBride's Avatar
    Fairfield Ca
    Have you looked at the "Growler" emblems?
    https://lmr.com/item/LRS-1117GB/must...BoCQCUQAvD_BwE
  12. #10
    Nov 2015
    Elverta, CA
    Man, those don't even look like a coyote. What were they thinking. Looks like the hellcat sorta..
  13. #11
    Lilburn, GA
  14. #12
    You may want to have something custom done by Billet Badges
    https://www.billetbadges.com/
    Lots of folks get some cool stuff done there.
  15. #13
    Billet Badges. First piece I bought for my car, last piece going on.
  16. #14
    Raleigh NC, OIB NC
    Quote Originally Posted by Brave Salmon View Post
    Think it looks more like a Coyote then a fictional cat.
    Kevin
    MKIV #8234
  17. #15
    Wheaton, IL
    Yes - the ones I'm getting from 2bking were made by them.
  18. #16
    Elk Grove, NorCal
    You'll be happy with the ones from billet badges. They are a small outfit but produce excellent products. I stopped by their shop just outside of San Diego and was really impressed with their work and had them custom make my hood badge. The only drawback (besides being pricey) was they couldn't print "Roush" on my emblem. We contacted Roush and they started the conversation off with "Well our legal team". Then I immediately new the answer was "No" unless I paid a huge fee. So instead I had billet badges print "427 SRTW"
    Kit purchased: July 25, 2017
  19. #17
    Member ChasNMe's Avatar
    Sep 2018
    Charleston, SC
    maybe a dumb question vspeeds, what is SRTW?
  20. #18
    Elk Grove, NorCal
    Quote Originally Posted by ChasNMe View Post
    Not a dumb question at all. The engine is a Roush SR (street/racing?) with a Twisted Wedge Mild cam-SRTW. Its really just SR but I added TW to take up space in the scroll. The original AC badge said “ Bristol”
  21. #19
    Wheaton, IL
    Quote Originally Posted by Vspeeds View Post
    Very creative!
