20
59
David aka Ducky2009
shark92651
I got a few more items done since my last update. I went ahead and mounted the paddles and the catches for the hood latches. For now I decided to just use the supplied pieces and rounded the ends. I attached them pretty much the way the manual shows with the bolts through the bumpers. They seems to work just fine for now and I can always modify it later if I feel the need. The hood certainly isn't gapped very well and the front corner on one side is too high but I think I will leave all that for the painter to fix.
If you give the hood latch brackets a concave shape instead of flat (or convex/rounded shape like the manual shows), the hood latches will stay in a closed position without being locked. I started off rounding per the manual, and the latches would rotate to the open position. Needed to use the key/lock to keep the hood tightly closed.
Build Thread:
http://thefactoryfiveforum.com/showt...MK4-Build-9035
