Likes Likes:  2
Results 1 to 6 of 6
Thread: Diffuser
    Jan 2019
    Diffuser
    The frame work from the engine on back pitches up. Does the diffuser follow this line? If so would aerodynamics speaking the diffuser going back level instead of pitching up would produce more downforce right? If I brought it straight back I could use the extra room for exhaust.
    Reno, NV
    It is the angle that makes the diffuser work. Check out this page for more explanation.
    https://www.racecar-engineering.com/...-aerodynamics/
    818R Build date 10/31/15
    Sgt.Gator's Avatar
    Bend, Oregon
    Another great source for Diffuser engineering:
    Willem Toet, former Head of Aerodynamics at Ferrari F1, explains the fundamental principles behind motorsport diffusers.
    https://www.racetechmag.com/2017/08/...ort-diffusers/
    Owner: Colonel Red Racing
    818R ICSCC SPM
    Jan 2019
    I haven’t said anything but I really want to design a bottom exit exhaust to increase air velocity under the car. But I’m not seeing the room.
    Bowling Green, KY
    I also mounted the diffuser a couple of inches further back.3-4 rear 818.jpg818 rear.jpg
    Your car is looking fantastic.
  6. Likes Bob_n_Cincy liked this post
    Sgt.Gator's Avatar
    Bend, Oregon
    I have a blown diffuser on my STI. There are lots of tradeoffs to them. I only did it because it was convenient and lighter, not to increase the under-car velocity. If you google "blown diffuser" you'll see the reasons it does and does not work so well. Here's a good start: http://www.formula1-dictionary.net/diffuser_blown.html
    I don't have it on my 818 nor would I think it's worth doing it. My STI with aero testing wool tufts attached:
    818R ICSCC SPM
  8. Likes Hindsight liked this post
