Thanks Thanks:  6
Likes Likes:  7
Results 1 to 40 of 56
Thread: Jeff's Roadster Build (GRADUATED Sept 2021)
    Jan 2019
    Question Jeff's Roadster Build (GRADUATED Sept 2021)
    Hi Everyone. Excited to be joining all of you. Just started a build of my Mk4 Roadster with a 347 engine.
    Early on, it seems that I've had a few parts of the front suspension missing. So far F5 has been good about replacing the missing parts, but fingers crossed it was just a few small bumps that I found first.
    Anyway, I have two questions about the front suspension setup:
    1. When setting up the upper front right control arm, I couldn't get it to the suggested alignment dimensions in the manual. The mounts bottomed out before I could get the right depth. The left side was fine.
    2. After mounting the spindle and torquing the nuts to the specified values, the right spindle is so tight I can't move it. The left spindle, however, is fairly easy to turn. Thoughts on why it would be tight to turn? Might it be related to the above issue with getting the alignment right? What suggestions do you have for me to troubleshoot this, or might it just loosen up later? I'm not sure how loose it should be, or if this indicates a problem with the ailgnment of the upper arm or if the balljoint has an issue. IMG_3028.jpeg
    Thanks everyone!
  2. Likes Kmcallahan liked this post
    Common mistake, but your ball joint mount plate is upside down. You want the ball joint angle to point outward, not inward. In other words, the taller part of where the ball joint threads in should be on the outside of the plate on the top side.
    Jan 2019
    Thanks -- painted the aluminum panels?
    Obvious now, thanks for pointing out my mistake.
    Question - I see you've painted your aluminum panels. What did you use for that? I've mounted two of mine already, but like the look....
    Quote Originally Posted by jeffisfast View Post
    Easy fix at this point. I sprayed my aluminum panels with Rustoleum bed liner. If I could do it over, I'd have gotten them powder coated or left them bare and wiped them down with Shark Hide.
    Jan 2019
    Hi everyone. Finally got a week off from work to work on the car! I got the IRS differential in without too much trouble; it needed two people's worth of elbow grease to wiggle into the right place.
    Now I'm onto the IRS suspension and having a really tough time installing the lower control arms. It seems that the tabs they should slide inside of are just slightly too narrow, or maybe the bushings the arms came with are slightly too thick. Is there something obvious I'm missing?
    Jan 2019
    Pic of the diff:
    Used to be that the tabs were often to wide by a smidgen, so maybe FFR has adjusted the tolerance on new frames. Can you use a rubber mallet to tap the arm in? Perhaps a tap to the tab's themselves. to spread them a bit?
  9. Thanks jeffisfast thanked for this post
  10. #8
    Very common for that fit to be tight. Best method in my experience, and the least destructive, is to use a threaded rod to spread them. Put a threaded rod through one tab, then a washer, a nut, run them all the way to one side, then another nut and washer. Now turn them so they're trapped inside the tabs, and use a couple wrenches to spread. Usually doesn't take a lot so don't get carried away. I would also suggest putting some grease into the control arms via the zerks. Good chance to make sure the grease is flowing through the bushings and they're fully lubed. Also makes them a little more slippery to install.
  11. #9
    Bakersfield, CA
    Hi Jeff,
    You garage picture reminded me that I sent you a PM back in April lol Did you ever get it?
    Kurt
    Build thread
  12. #10
    Jan 2019
    Thanks all. Heading to the hardware store for some threaded rod.
  13. #11
    Jan 2019
    Just as an update and a new question -
    1. The threaded rod, washers and nuts worked great. I feel bad for anyone who tries to muscle in without it.
    2. New question - the hardware that was included for the IRS upper control arms, the nut is super tight to get onto the bolt. Like I'm using all my strength with a breaker bar to get it on (the first few threads were easy but then it got real stiff). I've double checked I'm using the right bag of parts, but that doesn't mean the wrong parts aren't in the bag. I note that these are the deformed thread bolt, which might be code for hard to turn? Figured I'd ask a NOOB question to the experts here before I break my back needlessly.
    Thanks all!
  14. #12
    Dec 2018
    Hudsonville, MI
    The distorted lock nuts should likely not take that much force to seat, check the thread count on the bolt and corresponding nuts.
    Addendum: not an expert
  15. #13
    Jan 2019
    Just as a follow up.... not sure if I had too much or too little beer, but even though I double checked, I used the wrong bolts. Thanks again!
  16. #14
    I have encountered the resistance of stover nuts before, and was amazed at how much effort it took to tighten them up. So cross threading them onto the wrong bolt, must have been ridiculous...
    At a guess, I'd probably to say much beer...
  17. #15
    Jan 2019
    IMG_3946.jpeg Yes, I had to resort to cutting the nut.
  18. Thanks Kmcallahan thanked for this post
  19. #16
    Senior Member Kmcallahan's Avatar
    Jul 2019
    Midland tx
    I like how you have the chassis on the cart. That is a good idea to maneuver around .
  20. #17
    Jan 2019
    Hi Folks,
    I'm taking a week off from work and spending some time on my build. I'm now working on the accelerator pedal and have two questions for those that have been through this:
    1. My pedal came with the arms folded down so they are in line with each other. Looks like the connecting piece has been pressed into the pedal assembly. Do I need to get this out somehow to open up the arms? Any advice on how to press it out? Here's a photo of it:
    2. The throttle cable, where it passes through the firewall, the hole is actually slightly oversized for the cable's nut assembly. The entire cable passes through the firewall. What have I done wrong here? (Wrong hole? Wrong throttle cable? Do I need to add a large enough washer and nut?) Another photo:
    Thanks all!
  21. #18
    Jeff,
    That's the correct location for the throttle cable. If it's going through the hole, then you'll need a couple of washers to attach it the the foot box wall. Before you do, I'm not a fan of the kit-supplied cable and recommended buying a better one from Lokar. On the pedal, you just need to loosen the pivot and open it up like the picture in this post:
    https://thefactoryfiveforum.com/show...l=1#post289388
  22. Thanks jeffisfast thanked for this post
  23. #19
    Jan 2019
    Thanks Papa.
    An update and a new question:
    1. I ordered Russ' accelerator pedal since I broke mine while trying to unfold it (the bushing was totally locked in there).
    2. I also ordered the Lokar throttle cable and look forward to installing it tomorrow. Agree the stock one feels underwhelming.
    3. I've moved on to installing the power steering compatible steering rack. Looks like I didn't receive the FF5 sleeves for it, but I'm hoping for some advice to press out the pre-installing sleeves and bushings that are too big for the FF5. See attached photo. I don't have a press and they didn't seem to budge when I hit with a hammer.
    As always, million thanks!
    Thanks Papa.
    The installed bushings and isolators should just pull right out. The FFR bushings replace the ones in the rack or you can get the ones from Breeze that are offset. A lot of guys like them for better rack geometry, but I used the FFR ones and don't think the others are necessary. Did FFR ship you the rack or did you get it from another source? If you got it from someone else, you'll need to buy the correct bushings. If you got it from FFR, call them and ask for the bushings. Double check your inventory as they were not in the same package as the rack in my case.
  25. #21
    Jan 2019
    Thanks Papa. I just needed some special elbow grease to pop the existing bushings out of the FFR supplied power steering rack. All good now and I've got the rack installed in the car. The only hiccup I ran into was that I couldn't attach the Tie Rods to the underside of the bracket, they only wanted to go in from the top side -- looks like the bracket may be slightly tapered. See attached photos. So my question is, do they go in from above as I've done or did I do something wrong?
  26. #22
    Make sure you have the spindles on the correct side. If I recall, they go on opposite of the stamping for the roadster. In other words, the PS stamped spindle goes on the driver's side and vice versa.
    Edit: Looked closer once I got home and could see your pictures on a larger screen and the spindles look correct, but you could also have the steering arms reversed or upside down. The tie rod ends s should mount from the bottom as shown in the manual. Hey, at least you didn't drive them in against the taper! That's a common mistake that is a lot harder to fix without damaging the tie rod ends.
  27. #23
    Jan 2019
    Thanks Papa. I hope FF5 has you on the payroll!
    I'm not following what you mean about the spindles -- my problem is the steering rack tie rod ends don't want to fit from the underside into their brackets. I was wondering if they are internally tapered and I installed them on the opposite sides, but from the photos they seem correct?
    New question for the group about the fuel filter location. The soft fuel line supplied doesn't seem to be long enough to get to the filter mounting location shown in the manual. Is the manual wrong, do I have the wrong soft line, or should I just put it someplace else?
  28. #24
    Apr 2019
    NC
    Tie rods attach from the bottom, looks like you need to swap the steering arms to achieve that. Pic from another build.
  29. Thanks jeffisfast thanked for this post
  30. #25
    Jan 2019
    Got it, thanks. I mixed up the two steering arms but got that sorted.... Wish it were easier to take them off but live and learn.
    Any thoughts on the fuel filter location also mentioned above in #23?
  31. #26
    Apr 2019
    NC
    You can locate it rearward and inside rail that roll bar down tube attaches to.
  32. Thanks jeffisfast thanked for this post
  33. #27
    Jan 2019
    I see the spot you're talking about, Greg, but here's another dumb question. The soft line kinks if I mount it there because of its length. Can I shorten this line?
  34. #28
    Apr 2019
    NC
    Can reverse the connectors and see if that works or use a Breeze assembly that is longer and allows a loop https://www.breezeautomotive.com/sho...quick-connect/
  35. #29
    Jan 2019
    Hi Everyone.
    Happy Thanksgiving.
    Finally had some time off from work so I could come back and keep working on the F5! I've started running the wiring harness and the fuel lines. The wiring harness, so far, seems straight forward. The fuel lines, however, were a bit trickier and I'm now hoping for some advice.
    1. I've never used a tube bender and tried using the "Imperial Tube Bender" and crimped the fuel line. No way it will flow freely now. So this means:
    2. Can anyone recommend a better tube bender?
    3. Can anyone recommend what replacement hard fuel line I should order?
    4. Lastly, any good pictures of how you've routed your hard fuel lines? Looks a little messy/bendy getting down to the frame rail from the fuel filter location.
    Thanks everyone!
  36. #30
    Jeff,
    I used this tubing bender with good results for my Nickel Copper brake lines:
    https://www.amazon.com/Eastwood-Bend...5063753&sr=8-5
    I went with -6 braided fuel lines on my car.
  37. #31
    cv2065's Avatar
    I used the same tube bender and pliers that Papa recommended. Just go easy, especially with the pliers. They can damage the line if you get too aggressive. NiCop tubing is soft, so the tube bender you have is similar and will work, like I said, just go easy with it. Get yourself a couple of scrap pieces and practice before going the real deal. I used all pre-flared lines from the local Advance Auto. Worked great, you just have to plan everything out a little more carefully, as you are dealing with pre-determined lengths. I ended the hard lines with compression fittings from Breeze and then flex lines to the filter, tank and fuel regulator. Not one leak from the start. Mark from Breeze is great and he can get you setup.
    I'm not a master by any means, but feel free to browse my build thread for routing ideas.
  38. #32
    Jan 2019
    Thanks Dave. What are -6 braided fuel lines?
  39. #33
    Jeff,
    The braided lines are a flexible tubing/hose.
    The -6 is the size:
    Standard Automotive Hose Size to -AN Equivalent Hose Size
    1/4"= -4 AN
    3/8"= -6 AN
    1/2"= -8 AN
    5/8"= -10 AN
    3/4"= -12 AN
    1"= -16 AN
    1-1/4"= -20 AN
    1-1/2"= -24 AN
  40. Likes jeffisfast liked this post
  41. #34
    Jan 2019
    Hi Folks,
    Happy Holidays. I hope you're all using your time off to work on your F5, like me...
    While I wait for UPS to deliver parts and tools I'm catching up on assorted build items. One of them is lubricating all the suspension joints. I've got all taken care of except for the rear, rear upper control arms. I can't see any way to actually access the zerk while the arm is actually assembled. Am I missing something obvious or should I take the bolt out and just lube it and then re-insert and torque down?
    Thanks everyone and looking forward to 2020 rides!
  42. #35
    BadAsp427's Avatar
    Greeneville, TN
    Well..... Jeff.... Those should be pointing down... I would say that you have installed them on the incorrect side of the vehicle...
  43. Thanks jeffisfast thanked for this post
  44. #36
    Jan 2019
    That explains it.
  45. #37
    Jan 2019
    Hi All. I've got my suspension installed correctly, filled the diff with fluid, and even ran my fuel lines. All good stuff.
    New question. I'm working on the hard brake lines and it seems that the male fittings on the hard lines don't fit the female fitting on the master cylinders. Am I just not finding the right adapters or am I just not pushing hard enough to get them to thread in?
  46. #38
    Dublin, OH
    Dunno, mine seemed to fit just fine. If you're buying additional brake lines from an auto store, make sure you don't get the British or bubble flair ones. These won't mate with the cylinders or connectors.
  47. #39
    Silly question: Did you use the adapter or are you trying the thread the line fitting directly into the MC?
  48. #40
    Aug 2019
    Verona ILL
    Hose size explained
    Jeff,
    The -6 is the size:
    1/4"= -4 AN
    3/8"= -6 AN
    1/2"= -8 AN
    5/8"= -10 AN
    3/4"= -12 AN
    1"= -16 AN
    1-1/4"= -20 AN
    1-1/2"= -24 AN
    Not to nitpick but just to clarify. You are correct in that 1/4" is a -4, 3/8" is a -6. The Dash size refers to the size of the hose/tube in 1/16 of an inch, that is where the dash size comes from. Also the AN designation is from the military for Army / Navy, and this is also the same as a JIC fitting. The JIC fittings have a 37 degree flare as opposed to a 45 degree flare on a SAE fitting. The brake fittings we use in automotive on these builds have a 45 degree inverted double flare. The AN or JIC fittings we use on these builds are for fuel lines only, not the brake systems. Sorry mechanic all my life and in later years taught a class on ID of the various fittings.
    Mk4 9735 complete kit delivered 11/29/19 Gen 3 Coyote, Tremec TKO 600, Moser 3.55 First start June 25, 2020 First Go Cart July 20, 2020
