Likes Likes:  4
Thread: Rocket wheels advice
    Jan 2019
    Exclamation Rocket wheels advice
    So after much research and deliberation I have decided on the following rocket wheels for my 33 hot rod (without fenders).
    Rocket Booster Series, Hyper Shot
    Front 18x8, 4.5" backspace, 5x4.5 bolt pattern (Rocket Racing R16-886547)
    Rear 20x10, 5.5" backspace, 5x4.5 bolt pattern (Rocket Racing R16-2106555)
    I was going to run approximately the recommended tire sizes
    Front: 245/40/R18
    Rear: 305/25/R20
    Any comments or advice before I push the purchase button?
    Thanks in advance.
  2. Likes shmelty liked this post
    Sep 2019
    These happen to be the same wheels I've been looking at, I'd love to see how they look on the car.
  4. Likes Higgi56 liked this post
  5. #3
    Jan 2019
    Quote Originally Posted by DoBoy View Post
    Does the size make sense to you? Based on my math I'd have 25.72" tall in front and 26" tall in rear.
  6. #4
    Member Roger Pugh's Avatar
    Mar 2020
    Ephrata, Washington
    Higgi56,
    Those should look great! looking forward to seeing some pics when done!
  7. #5
    Oct 2021
    Curtice, Oh
    I would love to see these wheels on a 33. I was thinking of getting these. I keep seeing conflicting info on back spacing with IRS. Can anyone confirm what backspacing will work? Is it the same as solid axle?
  8. #6
    Senior Member Tampa33Build's Avatar
    Feb 2017
    Lutz, Florida
    I have :
    Front: 17x8 with 5” Backspacing
    Rear: 19x10 with 4” Backspacing
    Tires:
    Front: 245/40ZR17 95Y
    Rear: 285/35ZR19 99W
    Probably could have gone with 5" backspace on rear, however I like the wider stance. Had to modify rear fenders and changed rear coilovers to AFCO 3860 Eliminator Coil-Over Shock, Double Adjustable, 6 Inch Stroke with 250lb coils to get enough height. I have more than enough adjustment on rear now, they are set to about mid point.
    2022-01-15a.jpg 20220304_231904703_iOS.jpg 20220304_231804263_iOS.jpg 33_Wiregrass.jpg
  9. Thanks Jeff33Ford thanked for this post
    Likes WIS89, FF33rod liked this post
