Results 1 to 5 of 5
Thread: Rear Cockpit Panel - Harness Hole Interference
    Senior Member D02G's Avatar
    Mar 2019
    CT
    My rear aluminum panel doesn’t seem to be fitting right. I have it mocked up and the harness holes are sitting at the same level as the rear crossmember. I would have thought that the harness holes should fit above the rear cross member?
    Any thoughts on how to correct it?
    Brian
    Member ChasNMe's Avatar
    Sep 2018
    Charleston, SC
    pics would be great, but if i understand you . . . most people have said that you should have the crossbar cover a little bit of the bottom of the hole so that the straps dont chaf and get cut on the hole, they rub the crossbar instead. i think the pics i saw were like 1/16" or so of the crossbar shown at the bottom of the hole
    Norton, MA USA earth
    ChasNMe is right. the cross bar will block about half the harness hole.
    Mar 2019
    CT
    Okay. Thanks. It’s about halfway on mine.
    Raleigh NC, OIB NC
    Mike did not mention it but he makes nice finishers for the belt openings
    Kevin
    MKIV #8234
