64
146
View Poll Results: Startup with new ID1050x or previous EV14s?
- Voters
- 0. You may not vote on this poll
Frank818
I thought so there was a catch about a pull and push fan on the same setup, even though they would be on each other side of the rad/HE. That's probably we don't really see that kind of setup!
Isn't the hood blocking? I have 2 huge louvers in the hood to help air escape, would be counter-intuitive to me to block them off. Though I agree a lot of air does come out between the hood and windscreen.
The fact I don't use a shroud might also be a reason for hot idle.
He's talking about the space over the radiator, between it and the hood a very small space a little over an inch in the middle that tapers down toward the sides. Check out i think it's AZPete's thread where he posted this mod.
The shroud does make the fans much more efficient in directing the air the fans pull thru the radiator.
