The Dart 363 is alive
Still doing lots of carb tuning, but holy crap this is a lot of motor. Here it is at idle. Specs below
https://youtu.be/zP6Fh5LTj9Y
Compression comes out to 10.2:1.
Heads are twisted wedge 170cc
Rpm intake
Brawler 600 cfm mech secondaries
Custom cam from cam research (233/236 duration on intake/exhaust. .555 lift, and a 106 LSA)
4.125 bore with a 3.4 stroke
From the research and tests I have seen, my heads and carb are probably choking the motor. However, I’m sort of ok with that right now. It has excellent throttle response and is clearly faster than my 302 was, which dyno’d at 338 whp
Now on to fix the pesky oil leak from the back of the intake manifold. First time I messed that one up. I’ll let you guys know when I scatter my T5 lol.
Great sound with the engine. I'll bet it is quick.
Sounds great and look forward to seeing that beast in person.
MKIV Complete Kit #9494 l Delivered 1/5/19 l First Start
11/28/20 l First Go-kart
4/11/21 l Carb'd 347 l Mid-shift TKO600 l 3.55 IRS l P/S l Forte Mechanical Throttle Linkage l RT Turn Signal, Drop Trunk l Breeze Upper/Lower Radiator Support, Fan Shroud l Boig Upper/Lower Cool Tubes & Quiet Pipes l 18" FFR Gasser Wheels l
Congratulations Fellow Dart-Sider!
Unfortunately we both know that you and I are a pair of Pros when it comes to R & R-ing a power plant.
Congratulations Once Again & Wrench On Brother, Wrench On!
Thanks guys! And thanks Steve. I’m a happy camper man. Let’s catch up soon
Congratulations! Sounds bad @$$.
Once I had the intake at the rear wall leak. Fixed it the old fashioned way. Brake cleaned and air dried it 2-3 times. Put a glob of Ultra Grey sealer on my finger tip and smeared it on that joint. Made sure to work it into any gap. Let it dry over night. No leak. I like the Ultra Grey because it is a little thicker consistency than blue, clear, or black. Also the color hides pretty well at the edge of the aluminum manifold.
https://www.grainger.com/product/2GX...g!456311799524!
I don't remember if you have a compressor or not. If you don't buy a can of compressed air they use working on electronics.
https://www.walmart.com/ip/Dust-Off-...RoClwMQAvD_BwE
Originally Posted by
CraigS
Ahhh I soaked a towel in brake clean and cleaned it like that. Then used “the right stuff” to goop it in there lol. We will see if it works
Hey Scott, that engine sounds badass! Can't wait to see & hear it in person.
MK IV Roadster #8631
Does sound badass. I left the stock 5.0 cam in mine, one of my regrets. Oh well I’ll build a new motor one day.
What RPM have you got it idling at?
2017 FFR MK4 9026, 3 Link, 15" FFR halibrands, cooper cobra tires, '88 302/5.0, GT40 Y303 heads, Performer RPM intake Manifold, Holley 650 DP Carb, Pertronix distributor, T5Z spec built transmission, 3.73 rear end. Ordered Nov 2016, picked up at FFR Feb 2017, first start July 2017, Legal on the road May 2018, still in Gelcoat.
