Where did you all rivet your name plate? Texas doesn't hand out VINs so I don't need to worry about that since the F5R serial number is on the frame. I was thinking about riveting it to the top of the removable cover on the DS footbox so it will be readily visible when you pop the hood. Where did others place it? Any pics to post?
I wanted to be a bit different, so I put mine on the Breeze radiator cowl piece.
I put mine on the passenger footbox. IL issues their own VIN plate so I took the FFR plate to an engraver and got the issued number engraved before riveting it in.
__________________________
2017 FFR MK4 9026, 3 Link, 15" FFR halibrands, cooper cobra tires, '88 302/5.0, GT40 Y303 heads, Performer RPM intake Manifold, Holley 650 DP Carb, Pertronix distributor, T5Z spec built transmission, 3.73 rear end. Ordered Nov 2016, picked up at FFR Feb 2017, first start July 2017, Legal on the road May 2018, still in Gelcoat.
Originally Posted by frankeeski
In the envelope it came in.
Originally Posted by lewma
I think that's where I last saw mine too
Likewise..
The govt inspection facility installs the assigned BC VIN plate, once it pass's inspection, right next to the FFR frame stamp, and i also added an AC Cars one to my left footbox.
Top of PS footbox. Plus stamped the VIN in a couple of hidden places on the frame. It was suggested by the CHP during inspection.
If Brute Force doesn't work, you're not using enough of it. Basic Stuff: MK4 Complete Kit #8439, Wilwood's, 17" Halibrands. Extra Stuff: Stainless brake and fuel lines, Breeze cooling, Battery mount, SS Roll Bar. Old Fart Stuff: Heater, Seat Heaters, Footbox Fresh Air, Stereo, Keyless ignition, Power Steering, Hyd Clutch. Young & Dumb Stuff: 427w Dart, TKO600, 3 link Moser M9/Ford 9", 3.5:1, Eaton TruTrac Posi. Graduation Thread
Kevin
MKIV #8234
Coyote '14/TKO-600/3-Link 3:55 Rear I love the smell of 100 octane in the morning.
I didn't get an FFR nameplate with my kit in 2001. Is this something they started sending out after that?
