Time to clean house. Listed below are leftover parts from a couple builds. I’ve listed Factory Five part numbers and their prices where available. Included pictures for some. If you want a picture of something else, just let me know. Everything is 100% new and unused and many still in original packaging. Not trying to make a fortune here, but too good to throw away. Just want this stuff moved and out of here. Some items are free as indicated. In all cases, you pay the shipping.
Here’s how I’d like to do this which is simplest for both of us. PM what you’d like and your complete shipping address. Not just the zip code. (Can make a difference.) Sorry, U.S. addresses only. I use FedEx ground. I have an account so get a slight discount. I’ll let you know the actual shipping cost. PayPal is highly preferred. Upon receipt of payment, I’ll drop at FedEx either that day or the next and provide the tracking number. I’ll update the list when items are no longer available.
FF 16460 Gates T-Filler PN 23577, w/20 PSI cap. New $25.00, asking $10.00
FF 12354 Headlight Switch. Note: Does NOT include the nut or knob with shaft. Switch only. New $25.00, asking $10.00
FF 15439 4.6L TKO Transmission Mount Plate. Note: Also required for Roadster Coyote/TKO installation. Asking $10.00
FF 14554 PS rack adapter. Note: Missing two set screws, but common parts. Asking $15.00
FF 16291 Wilwood cable clutch quadrant (5) laser cut steel pieces, less hardware. Asking $25.00
FF 14652 fuel line + fittings + clamps. Unopened still in bag. Asking $20.00
Bag of fuel system components, including fuel filter, mounting bracket, (2) fuel tank vents, fuel filler gasket, fuel line connectors, tank to filter fuel line, clamps, hardware. Asking $30.00
FF 15030 Stainless Overflow Tank Kit, includes tank, mounting brackets, hardware. No hose or hose clamp. Asking $30.00
(1) FF 13775 Accelerator Cable Components. Includes cable, connector, lock nut, nylon nut, spring. Asking $15.00
(2) FF 14897 Mevotech MK772 upper ball joints unopened in box. New $20.00 each. Asking $15.00 for both
(2) FF 10888 Shifter Handle Components LESS trim ring. Includes balance: Shifter, boot, knob base, knob, shifter bolts, #8-3/4 screws. New $96.00 each, asking $20.00 each
(2) BR33-8286-BA 11-14 Mustang lower radiator hoses. Note: Included with Ford Performance Coyote controls pack. Free
