Results 1 to 10 of 10
Thread: 818C Door Locks
    Member LearningCurve's Avatar
    Haymarket, VA
    818C Door Locks
    Anyone had any luck with the driver side door lock on the 818C?. I can't seem to get enough rotation on the lock to trigger the lock/unlock mechanism. There just seems to be too much flex on the "L" bracket and the bracket attached directly to the lock. I also just realized that I have that bracket installed upside down compared to the photo in the manual. I am not sure if this would make much of a difference as the rotation should still be the same.
    If anyone has any tips for this please let me know. I can't find much of the topic when searching.
    https://photos.app.goo.gl/6LhtN5wHyCxu9qU96
    818C - #458 | Delivered-11/16/16 | First Start/Go Kart-8/24/18 |
    Daily: 2004 WRX
    Weekend: 2012 S4
    Jun 2017
    Had the same issue.. I just made my own bracket and it worked a LOT better
    Haymarket, VA
    Quote Originally Posted by kcarlasc View Post
    Do you by chance have any photos of yours setup? I am still struggling with getting this to work properly. What I think would work is if I had a bracket that attached to the key lock/unlock mechanism that had a much larger engagement area. With the provided bracket, there is a large area where the key lock/unlock mechanism just spins freely without actually engaging with the bracket. I tried to fabricate my own but was not able to due to the tight tolerances needed.
    https://photos.app.goo.gl/9QPXrAztC9Yd4D2k6
    Daily: 2004 WRX
    Weekend: 2012 S4
    Senior Member AZPete's Avatar
    I can't help with your key lock question because I used different door handles, but if you saved the donor door lock actuators you have a work-around. See this thread, post #21:
    https://thefactoryfiveforum.com/show...nished-I-think
    Jun 2017
    Quote Originally Posted by LearningCurve View Post
    Sorry I don't.. I just used a piece of straight piece of aluminum and it work out fine.. Much better than the L shaped one..
  6. Thanks FFRWRX thanked for this post
    Baldwinsville, NY
    I used the provided "L" piece but had to make multiple bends and twist to make the bracket fit and provide clearance to the glass. I would not finalize anything until the glass is installed. I also installed a spring on the bolt between the top "L" piece and the bottom of the lock mechanism to prevent it from rattling. Unfortunately I was not able to find pictures. I remember experimenting with multiple bolt lengths as well. Hope this helps.
    Sep 2015
    Hamersville, Ohio
    Door poppers! No outside handles or locks!
    Apr 2014
    thats 100% what I did. Push button opener inside and used a door lock controller to pop the doors outside. with manual releases ran just incase.
  10. #9
    Feb 2019
    Houston, TX
    Quote Originally Posted by Newkitguy View Post
    Do you have a link to details? This is on my list of things to work on in the spring.
  11. #10
    Apr 2014
    AJ i don't have a link as I don't have a build on the forum. but if you have any questions shoot em over and i'll help where i can.
