![Forte's](https://www.factoryfive.com/wp-content/uploads/2015/04/fortes.gif)
Russ Thompson Turn Signal wiring question
Sorry if this has been beaten to death, but I've searched here for the answer and couldn't find it so I'm throwing it out to one of you that's smarter than me:
Using the Russ Thompson Turn signal kit ONLY for turn signals - NOT headlights, flash to pass, horn - nothing but turn signals.
Question: Do I need any relays for this or can I wire it directly? I'm not using LED's, just the FFR stock lighting. If I need a relay, what do I use?
Thanks for any advice you all can provide me with this.
Phoenixmsb
You don't say what wiring harness. Going to assume the usual kit provided Ron Francis harness. If so, no relay(s) needed. The RT turn signal switch is exactly the same, and wired the same, as the SPDT turn signal toggle switch shown on the Ron Francis wiring diagram. Power comes into the center common wire, and left and right wires connected to the corresponding switch wires. Easy.
The relays often shown and discussed are for the headlights, high/low beams, etc. Not related to the turn signals. You can use the momentary switch for the horn if you want. The standard RF panel already has a horn relay, so that's as simple as connecting to the two wires. Again, duplicating the horn switch shown on the RF wiring diagram.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
THANK YOU!!!!! Sorry, but yes, I'm using the RF wiring harness. I'll get them wired up and not fret so much anymore.... at least about this one!
Thanks again!
25th Anniversary #9772
hope you get figured out - I just talked to Russ to get a switch when my car parts arrive
![Replica Parts](https://www.factoryfive.com/wp-content/uploads/2015/04/replicaparts.gif)
