Results 1 to 20 of 20
Thread: Finally GTM #159 gets CA license plate
    Apr 2019
    Hi All,
    just want share, I finally got my SB100 and License plate, have a personal but will be few months, Still lots of stuff to do and finish but at least pass registration.https://thefactoryfiveforum.com/imag...es/biggrin.png
    The interior roof is not finished and glave area but for most part there.
    Have put about 100 miles on the car, I actually drove it back and forth twice to referee, first expression LOUD, gets Hot, every one once to take look and glad I have power steering, will get some driving to get use to this and trust the car.
    Added some dash picture. all hardware and all the controls and all the sensors inputs were designed by myself, picture really does not show all the stuff that is there and how it works, I will get a friend and get some video but a bit at a time.
    Thanks for all the help it has been a long but quick 10 years.
    Mostafa20191103_172455.jpg20191103_172731.jpg20191103_172851.jpg20191103_172921.jpg20191103_172921.jpg20191103_173143.jpg20191103_173235.jpg20191103_173510.jpg20191103_173901.jpg20191103_174229.jpg20191103_174456.jpg
    Senior Member beeman's Avatar
    Indiana
    Looks great! Congrats on the plates too.
    GTM #304 LPE 525hp LS3
    Congrats, dash looks great. Enjoy the driving fun.
    Newcastle, Wyoming
    Dash looks great and enjoy the ride...
    Member claybags's Avatar
    rio rico,az
    Congrats on the "milestone" Mostafa, and I am truly amazed at the electrical work you , Shoeless, and Tino have done! Wow!!
    Cheers, Jeff
    GTM 422, LS6, cam, heads, Mendeola trans
    Jul 2014
    Nice work, looks amazing!!!!
    Indiana
    Just saw you are monitoring tire pressures AND TEMPS? How are you doing that?
    San Diego
    Infrared sensors would be my guess. We have thought about it but to do it properly for racing conditions we would need three sensors on each tire. A lack of data channels and the expense of the sensors limits us to not doing this. We likely will put pressure sensors on in the near future as we can tell almost as much via the pressures. It won't help with setup, but we will be able to tell when we are over working a tire or tires.
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
    Apr 2019
    Just like OEM do, Radio Freq. for now for ease of use I have the cap sensor type transmitters but could be inside tire as well, but I like the external ones easier to replace.TPMS.PNGTPMS_01.PNG
    Nov 2019
    You have two fuel tanks? How are you reading them? That is not OBD2 data;
    Apr 2019
    Welcome to forum.
    There are hardware that reads each sender, measure resistance, scales it and then sends it to main computer, the dash allows manual selection of the tank and if pressure drops below 30 ( can be any PSI) then will change to the other tank automatically.
    Also the dash will dimm out a bit for the not selected tank but still bright enough so one can see the fuel level.
    add some more, not sure why it was not working last night
    MostafaIMG_8070 (2).jpgIMG_8058 (2).jpgIMG_8009 (2).JPG20180718_165820 (2).jpg20180718_165820 (2).jpg
    Nov 2019
    Thanks for Welcome;
    I am still confused; It appears you are reading fuel tanks, TPS and OBD data on your dash at same time? Also, you have two displays, what does second display do?
    Sorry for all questions, I am trying to plan for my build, finding it hard to find parts for this; or if I have budget...
    Apr 2019
    For GTM analog gauges will be part of the kit not sure about the other kits, but LCD gauges and all the other info build into them gets a bit more complicated, some very expensive, mind was under $400 for each display.
    Hopefully I will find some time and get some video as what thing do. My Hardware a bit more complicated for me to explain right now but hopefully sometime soon I will get to that parts.
    Mostafa
    Apr 2019
    BTW, thanks all for the support and Kind words, it has been pleasure to be part of the discussions. hope I stay connected.
    Jul 2014
    Hey Mostafa,
    Where did you source the steering wheel lighted buttons from? Those are sharp and I’m starting to kick around my steering wheel button plate ideas and would like to take a look at those.
    Sean
    Dallas county, TX.
    Very very nice. A+! Congrats!
    Apr 2019
    Thanks Much.
    it is crazy as how much more work there is to just make all the hardware and display to work.
    Today I finally got clutch interlock in place, could not find a nice place for the switch. also got the Hatch popper in, not sure what people do here mine does not pop up much, needs a handle!, will have to figure something out. but next week, being hospitalized tomorrow for few day or more, hope to make it out.
    Sean, here is the link, https://www.ebay.com/itm/LED-Metal-M...72.m2749.l2649
    Mostafa
    Jul 2014
    Thank you Sir.
    Newcastle, Wyoming
    Good luck Mostafa hope all come out well, I have been fighting a really bad sinus infection but think I final have the upper hand now, lost of antibiotics and staying out of dust in shop, but did get back to it this weekend, again good luck and may the force be with you !
    Apr 2019
    Thank guys, I made it back but was tough 10 days or so, thing are better now and hopefully will recover fully soon.
    Mostafa
