What does everyone use to adjust their coilovers? The kit doesn't come with a tool.
33 Hot Rod w/ deluxe 32 nose
350 SBC and 700r4 automatic, 8.8 rear with 3.55 gears
Order date:4/25/19, Deliver date 6/10/19
First run 10/6/2019, Go cart 11/3/2019
I used an oil filter wrench, I protected the ring so it does not get marred, and I placed a bit of copper sulphate grease on the shaft of the shock so the ring does not bind. Just remember to screw in the lock pin after.
Andreas
You can get the correct tool from Summit Racing. Use the correct tool and you won't damage the adjusters and use never seize on the threads so they won't gall. Never adjust them with the car's weight on them -- jack up the end you're working on and let the wheels hang free before adjusting spring pre-load.
It actually does come with a tool, Its a bare steel piece with a half moon shape on one end and a square tab off the end of the half moon. it has a slight bend at the end of the handle end. If you cant find it let me know, I have a bunch of them and can send you one.
FFinisher/AKA RE63
Do you happen to know what box?
Naz, yes I do take the weight off the wheels
The tool is pretty inexpensive. I ended up with a set made by Tokiko, as that's what they had in stock.
https://www.amazon.com/Aluminum-Coil.../dp/B00PC7PIVC
Teng Tools 50-120mm (2 Inch - 4 3/4 Inch) Adjustable Hook Pin C Spanner/Wrench (Pin Size: 6)- HP2036 available from Amazon among others. Use in conjunction with a strap wrench and you are good to go.
On my Konis, the ring is a pin style, not slotted like some motorcycles. The adjustment wrench has to be a pin type for Konis shocks. The first one shown above won't work on the konis. You need the second one shone by teng tools. I bought one and still had to grind the thing to fit the contour of the ring. Also, a drift punch of right size also works just as well for a he'll of a lot less money.
I had one spring collar that I couldn't turn by hand and this worked great.
Naz, far be it from me to argue with an expert builder such as yourself, but wouldn’t the never sieze attract road grime as you drive? I’m afraid of the grit in the grease causing problems. Aluminum is so soft that it galls easily and when two aluminum elements are in contact I fear for pickup, thus permanently locking the nut onto the sleeve. I have always used a fry lubricant on mechanisms that operate in dirty environments. I used spray-on Teflon on mine. If it doesn’t allow enough lubrication, dry moly could be added. What do you think?
We actually have an adjustable oil filter wrench that can be disengaged and sized, wraps around well and easy to use even in some tight spaces. As well we placed a very small amount of copper anti-seize to allow it to be adjusted easier wiping off any excess, has worked great and does not affect the lock screw.
Andreas
Maybe I am missing the point but I have a pair of wrenches that I got for my double adjustable QA-1's. They came as a set and they are obviously for specific purpose on the top and bottom rings. This is very handy to break the rings loose when adjusting. NAZ hit it right.
After trying to keep the tube from turning while I cranked on the ring with the spanner (almost impossible on the front) I pulled the shocks and adjusted then on the bench. It was easier to hold the ring with the spanner and crank on the tube with the strap wrench. I did put oil on the threads and cleaned it off with acetone when I was done.
I think I bought these at Summit. They are for the QA-1's as well so would not be for everyone.
