Book says 5/8 off-center? any reason why not centered?
That's a leftover from the donor radiator days. If you have a new kit supplied radiator, it can be centered.
I didn't know about the "hold-out from donor days" and installed mine with the offset (Coyote power) in #9365. Having it offset actually helped with needed clearance for the drain petcock, so consider it...
John D. - Minneapolis 'Burbs
Position it so that you can get the upper hose clamped on and let it fall where it may whether that is center or offset.
I just installed my radiator and I offset it the 5/8" because I wanted the side aluminum pieces to fit properly as designed. I wold have rather had it centered (just because i like symmetry) For those who center theirs what do you do about the side pieces?
-Tim
Radiator looks a bit funny with the offset but you need it for clearance. You can hide the whole thing behind a Nomex honeycomb that will also protect the radiator from stones.
Kevin
MKIV #8234
I had absolutely no luck getting the F5-provided aluminum pieces to fit. With the curve of the aluminum side pieces placed to match the contour of the body, I had a 1”+ gap at the bottom of each side piece. Also, the bottom piece was too long to fit between the outriggers (easy enough to trim) and also too wide to fit between the bottom of the radiator and the lip of the body opening. So I ordered the Mike Everson piece (http://www.replicaparts.com/Roadster...nel%20page.htm).
MK IV Roadster #8631
+1 on Mikes part. Never even considered using the FFR pieces. Wanted a smooth no seam duct.
EDIT: Forgot to post. The two pieces seal against the body forcing 100% of the incoming air through the radiator. Don't recommend it but have never installed the fan shroud I got after the car was finished. Car has been through 4 Carolina summers as a daily driver & the water temp has never gone over 210*F stopped in traffic. Normal running temp is 180*F with the factory thermostat.
Kevin
MKIV #8234
Before you do all this take a big hammer and knock your driver side frame horn towards the passenger side a .5 inch....knock the pass side outboard 1/4 to .5. It's where they need to be,,,da bat
Thanks John. I placed the side pieces in where I think they belong and noticed a big gap between the pieces and the radiator but was not going to pass judgement until I had the body on and could see how it all came together. Now I'm not as confident. If I end up not using the F5 parts and go with something like the Mike Everson piece I'll go back and center the radiator if it doesn't cause any problems.
I'd sure like to use some of the parts I got with my complete kit, LOL. I've upgraded a lot of stuff already.
Tim
