In my old Saleen days had the specs for a front end performance alignment done with my more than adequate weight in the seat
Anyone have roadster alignment specs they found to be good and will share for our machines?
1414K
Less is Less
Street car with manual steering;
.5 to .75 degree negative camber
3 degrees positive caster
1/16" to 3/32" total toe in
With power steering go to 7 to 8 degrees positive caster
Will use your specs. no power steering (only power anything is engine)
Thank you
Last edited by Swamplife2; 11-15-2019 at 07:41 AM. Reason: made better and more thanks
1414K
Less is Less
PS
Waxing bad, driving good
1414K
Less is Less
Couldn't agree more.
Jim
As Rich said nothing bad will happen but more positive caster=higher steering effort. You have a very slow ratio rack and with a slower ratio comes lower steering effort so you can probably go up a bit without the effort becoming uncomfortably high. Feeling strong?
FWIW, My MKII is set at +3.5° with 275x40x17's up front with a 4 turn lock-to-lock Flaming River rack, 22# air pressure up front - and in 18 years, I have gotten very used to the effort to park and it's not an issue for me.
Doc
