A perfect 60 degrees and a beautiful open sky makes for a wonderful day for a drive. Spent about 45 minutes out and about with no purpose but the drive. Crossed over 200 miles today.
Enjoy the journey and then enjoy the drive!!
MKIV Complete Kit: 3-link, vintage gauges, glove-box dash, chrome roll bars, 17" wheels, B/T leather seats, Gas-N side pipes and headers; Drive train: Levy 408w w/carb, TKO600, Moser 8.8 with 3.55s and GT rear brakes; Paint: Jeff Miller Ford Magnetic Grey Metallic with BMW Titan Silver stripes
Ordered: 4/5/16, Order completion: 5/14/16, Delivered: 5/24/16, First start: 6/22/19, Registered and legal: 10/28/19
That's a beautiful view. Enjoy every chance you get as we, here in the Midwest, have put our cars away for the winter. I will live vicariously through all the videos and pics that will be posted by the owners in the South and West.
Scott
Built FFR9457. 351 Windsor, TKO600, 3.73. Fitech EFI. Russ Thompson throttle pedal, turn signal, and trunk pan. Carbon Fiber dash with Speedhut Revolution gauges. Paint by Jeff Kleiner.
OK .... Thats kinda scary !!! You were out for 45 minutes and went 200 miles (lets do the math) and had one hand off the wheel to take PICTURES !!!!!
never mind ... you are talking total miles aren't you. Nice picture. Any more???
What do you think of a sub forum (admins) under general discussions "where I've been" or "my travels" or something along that line to group pics and stories of driving???
Nice time im sure, should have done myself but had fb to watch, tomorrow it is happening!
Walt
FFR8237 Donor build 89 GT , MK 4 , T5 , 17 " hallibrands 9" front 10.5 rear ,4×4 headers stainless mufflers, dual chrome roll bars, coil overs all 4,A/C and heater , soft top, 3:55 gears.
Ha! Indeed. No, I kept it mostly within the speed limit, and crossed over 200 total miles since it hit the road about 3 weeks ago.
I did have a guy in a Tesla wanting to show off his torque. I just let him show off by himself while I casually grinned along my way. He's got me beat in torque, but I guarantee I have him beat in satisfaction and driving enjoyment. Mine also sounds and smells better (if you like the sound of a lope-y cam and nearly open exhaust along with the smell of gasoline and exhaust fumes...which I do, very much).
I took it out yesterday evening for a quick run to pick up a food order, and had a conversation with a few guys who pulled into a parking spot next to me in a Mustang. They had a hard time believe that it was assembled by me in my garage (one of them wanted to know if I owned a shop in town).
Last night I put it on on stands, loaded the rear suspension and re-checked the pinion angle, as I had a pretty strong vibration through the shifter in 3rd gear when pulling hard up to 5000rpm. Sure enough, the angle difference was a bit low (just shy of 1 degree), so I adjusted the upper link a bit to put me a bit closer to 2 degrees down (1.6 right now, IIRC), and will try it out again next time I have a chance. I think when I set it the first time, my magnetic analog angle finder wasn't getting it done. This time I used an angle finder on my phone and took three measurement on the crank pulley and three measurements on the face of the pinion flange to get a bit more accurate.
--Nathan
We did a 2.5hr loop of CA76/79/78 in San Diego. Tanned the left side of my neck on the way out then the right side on the way back . I think i've just crossed 600miles.
Build 2: Gen3 Coupe Complete Kit #309 Ordered 1/25/21, Delivered 6/9/21 - BluePrint GM 427 LS T56, IRS, AC, Power Steering. Album Here
I took mine out for one of the final nice drives before winter sets in. Started the day at 42 degrees, which was pretty dang cold to me when going highway speeds. But then the clouds left, the temps rose, and it was one of those magical days that those of us in the car community cherish.IMG_20191106_115340.jpgIMG_20191106_110049.jpg
MK IV Roadster #8631
50 degrees and cloudy
Also great day for my driving as they all are
Pushing 50,000 miles
1414K
Less is Less
Got to do about 60 miles today, weather was perfect 78 deg. & sunny.20191119_142546.jpg
Walt
[ATTACH=CONFIG]117815
We took the crew up to VT recently for foliage viewing. Around 200 miles that day. Now we're into snow so sad times for the roadster crew now until spring.
I can’t wait until I get to post my own pictures like this.
