Likes Likes:  3
Results 1 to 4 of 4
Thread: Early Christmas present from my son
    Ohio
    My son works in marketing and decided to put my Mk4 build pics together in a video as a Christmas present. Brings back a lot of good memories of my build. CanÂ’t tell you how much I enjoyed it. There were challenges but with the help of family and this forum the car is finished. A very enjoyable experience. Thought I would share this with the forum. Enjoy
    https://youtu.be/cl9ssI7To7o
    JRL16
  2. Likes Straversi, FF33rod, Boydster liked this post
    mburger's Avatar
    Punta Gorda FL
    That’s awesome! Great gift.
    Mark
    Super Moderator
    Ray's Avatar
    La Mesa, California
    VERY COOL!!!!!!
    Ray
    Nice Video!
