Likes Likes:  7
Page 2 of 2 FirstFirst 12
Results 41 to 45 of 45
Thread: Website errors - timeouts
    mburger's Avatar
    Punta Gorda FL
    Various errors, including database errors, 503 and slowness has been intermittent for about 2 weeks.
    I will document the error next time for troubleshooting with the host provider.
    Mark
    Jun 2018
    North Vancouver, BC, Canada
    Quote Originally Posted by Just puttering View Post
    looks like 503's from about before 11 to after 12
    I had problems much longer than that. Couldn't access at 0600 PST, service unavailable and tried every once in awhile after that with service unavailable/database error/timeout.... until finally around 1230 PST we're up again. During that time, it would come up in my browser every now and again only to get an error when I clicked on a thread to read....
    Gen 1 '33 Hot Rod #1104
    Sep 2019
    Fredericksburg, VA
    Had problems today too
    Senior Member Kmcallahan's Avatar
    Jul 2019
    Midland tx
    I have been getting error messages same as mentioned in above post. I am also having to log in multiple times when moving around in forum. I am also getting an error message when attempting to add pi’s to an album. The error message states an error has occurred you need to log back in or you do not have permission to perform this task. Need some direction.
    Sep 2019
    Fredericksburg, VA
    I think I have a solution for the multiple logons in a session. Check to see if you clicked the remember me box right next to your password....it’s a small little box. Lemme know if that fixes the issue.
    Quote Originally Posted by Kmcallahan View Post
