Thread: Nose Locating Plate Options
    Atlanta, GA
    I have not 100% committed to my nose locating plates. The fitment of my hood looks pretty good, but because of my asymmetric hood issues, closure requires some effort to get the pins to seat in the locating plates. The problem is that they hang in the plate cup and require a nudge in the right direction, like the Fonz with the jukebox. It could be smoother and it causes some wear on the plate.
    I am wondering if I should go with it or shoot for something better. I feel like the locating plate could be designed better to guide the pin into position. I like Forcefed1's design from his Curvy Road build thread. He obviously has access to machining equipment.
    Wondering what others have experienced here. I can't seem to find anything premade that would be better and I am not totally familiar with how to have something custom fabricated.
    Gen 3 Coupe, Gen 2 Coyote, Wilwoods, IRS, Power Steering, AC JDAVIS500 Build Thread
  2. Thanks CTHiker52 thanked for this post
    Edmonton Alberta
    I used the kit parts with an acorn nut to locat the hood, seems to work well.
    you can see the nut at the front corner in this picture.
    David W
    Mkll 4874 built in 2004
    I see you commented in my build thread about how I did this, so won't repeat the details here. But will say I too noted some light wear on the locating plate Factory Five supplied. So I increased the taper on the guide pins I'm using (cut off 3/8-inch bolts) and seems to locate better with less drag and subsequent wear. The other thing I found is with the roller wheels I installed, also in my build thread, the hood comes down almost exactly aligned into the locating plate. So that seems to help a lot too. I agree those parts from Forcefed1 are cool. I have some limited fabrication tools, but nothing to do that. Very nice.
    Atlanta, GA
    Yes, Paul. I have noted your installation and I fashioned the pins as you recommended. I am fighting the tension/force created to get the hood far enough rear to engage the pin into the hole in the plate. That is the"nudge" I am referring to. It is improved with a more tapered pin, but still an issue. It all works well together, but was looking to eke out some improvement.
    David, you must have excellent hood fitment. My hood would not get into proper position with just a dome nut.
    Edmonton Alberta
    yes my hood fit is really good but it cost some $$$ for the body guy to do it. No rollers and it just fits.
    David W
    The steel piece looks like it has a flattened out bottom. If it does, and you have a torch, I bet you could warm it up w/ a torch and then hammer a more tapered bottom into it.
    Port Charlotte, FL
    I used a carriage bolt and rounded off the head. I also have the roller wheels which help side to side but not front to back. My issue was the hood shocks were pushing the hood when closed and it never seemed to close the same. Solution was to take off the shocks and use a prop (thanks Erik).
    Henry
