Results 1 to 3 of 3
Thread: 818 pitch stop?
    Portland, OR
    818 pitch stop?
    I am curious what people's thoughts are on adding a mounting point to be able to use a pitch stop for the engine on the 818. Even with stiffer mounts it seems like putting all the load through the lower mounting points could be a bit much. Or is it not worth the effort?
    Quote Originally Posted by autostang View Post
    I added an additional mount/pitch stop to the front of the WRX engine and to the rear of the trans. Now there is no engine movement at all. Others have used racing motor mounts.
    Harley818's Avatar
    Vancouver BC
    I used the STI type N mounts but no pitch stop and have no issues with excess movement at all. There isn't much movement. I'm Running around 260 HP.
    I have heard that the stock WRX motor mounts do move quite a bit.
    Harley
    Bought 2002 Donor Jan 2014
    First Start Jan 18, 2015
    First Drive Feb 14, 2015
