Results 1 to 3 of 3
Thread: Trick Flow top end (TFS- K514-360-SPC) with Boss 302 block (M-6010-BOSS302)
    Dec 2012
    Has anyone installed Trick Flow top end kit (TFS- K514-360-SPC) on a Boss 302 block (M-6010-BOSS302) ? Both are listed in the Challenge series rules. Boss 302 block requires 1/2 in. head bolts but the Trick Flow head from the kit uses a 7/16 in. bolt.
    Wareham
    Dave,
    We did it for those same TFS heads on the 25 hour car using a 363 short-block from Ford. We just drilled out the heads for the 1/2 inch bolts. If you look at the description for heads on Trickflows site it has a little note at the bottom that says must be drilled out if using 1/2 inch head bolts, so that is not something they haven't accounted for material thickness wise. We used a drill press and went in small bit increments but if you aren't comfortable doing that it's something any local machine shop would do.
    Jim Schenck
    Factory Five Racing
    Dec 2012
    Thank you Jim !
