Has any body had any luck with non block hugger headers?
Was wanting to see what fit, due to the proximity of the chassis and the heads.
Thanks!
Thanks!
I used Sanderson CC16 for early Camaro/Firebird. They fit perfect but they are huggers. I couldn't get anything else to work the way I wanted. They give you plenty of room for the wiring and steering on the drivers side and lots of room for the starter and AC/heater hoses on passenger side. I used a mini starter so a ton of room and easy to get to. Plug access is another story![]()
I was wanting headers to exit the engine compartment between the front tire and the door and use collector muffs.
Kinda like IMCA Modified headers or gasser headers.
Just found these. If they don't fit...I can make them fit.
https://www.daymotorsports.com/schoe...ers-adjustable
Part#:SCH-161-38
