Thread: transmission tunnel cover
    Apr 2019
    has anyone mention that there trans.tunnel cover doesn't fit well. mine seems to be bent too wide, therefore its bowed in the center and sticks up making in impossible to screw it down on the top.. i don't have a brake to reform it.
    I'm not Factory Five but you may/may not get a response from them. Don't know how actively this area is monitored. I see from your other posts it appears you're talking about a Mk4 Roadster. Probably would help to mention that since there are many other models offered. When you get more posts (20 I believe) you can add your build info into your signature line. For your trans tunnel cover, hard to say how bad it is without more description or pictures. But many of us make them removable so only attach them along the edges. Putting rivets through the top, like they show in the manual, isn't a requirement. Maybe it's OK as is?
    Sep 2019
    Fredericksburg, VA
    Edwardb,
    What are common needs to have the transtunnel cover removable?
    Senior Member delta0014's Avatar
    Jun 2019
    Atlanta, GA
    I bought a thicker, aftermarket transmission tunnel. It comes without the center hole so you can drill your own. Looks like it'll work great so far, I just plan on using some strong velcro strip along the sides to hold it in place.
    25th Anniversary Roadster #12 of 25
    Gen 3 Coyote
    TKO 600 mid-shift
    Car
    wallace18's Avatar
    Trenton, Florida
    You can trim it to fit without the 90 degree bends facing down if you want to. I have done this in the past on some MK4's.
    Quote Originally Posted by Aircontroller View Post
    Edwardb,
    Mainly because it makes the transmission easier to install and remove. Whether attached to the engine as one unit, or removing it by separating from the engine. In addition to access for lifting, often it's necessary to remove the shifter assembly. Way easier with the cover removed. A secondary reason, and not so important probably, is many including me prefer to cover the trans cover with something other than carpet. Vinyl or leather wrapped around the edges, often with stitched corners, is a nice look. Pretty much requires the cover isn't permanently attached.
  7. Thanks Aircontroller thanked for this post
    Sep 2019
    Fredericksburg, VA
    Thank you!
