Thread: Looking for plug and pin kit
    Jul 2014
    Hey guys,
    I've done some looking but am having trouble locating a plug and pin set for the plug that goes into the in tank fuel pump setup pictured below. I have the Lingenfelter high-flow pump, but should be the same as the OEM connector.
    Anybody know where I can source one of these plug and pin sets?
    wallace18's Avatar
    Trenton, Florida
    online Corvette salvage yards will have it.
    https://corvettesalvage.com
    Senior Member beeman's Avatar
    Indiana
    Not sure, this Fuel Pump Adapter Harness (FPAH-001) by Racetronix looks like the same pigtail...
    GTM #304 LPE 525hp LS3
    Jul 2014
    Quote Originally Posted by beeman View Post
    That looks darn close, I'll have to give them a call and double check. If this one actually fits, it looks like it's a GM Delphi / Packard - 4 way square metripack 150 male O2 connector Kit. Found it on Ballinger Motorsports for $6.99 after reading the details on the Racetronix website.
    https://www.bmotorsports.com/shop/pr...roducts_id/868
    Apr 2019
    This is what you need.
    https://www.racetronix.biz/product.asp?ic=iph-008.
    I think The metripack 150 is too small, is is closer to 280 than 150 due to higher current needs.
    Jul 2014
    Quote Originally Posted by KGTM View Post
    Now that looks exactly like the plug that goes from the internal flange side to the pump itself. I just took it apart again to verify and sure enough that's the plug on the inside. Now I just need to source some new pins. Thanks for the help KGTM!!
    Apr 2019
    no problems.
    I used the OEM cable just pictures and source the mating end that it is easier to get.
    Dec 2017
    Dallas county, TX.
    Powerandsignal.com and mouser electronics have the pins and plugs. One of the C5 manuals will spec the connector and pin type.
