Results 1 to 18 of 18
Thread: Windshield Brass L Brackets?
    cv2065's Avatar
    I was reassembling my windshield and one of the brass/copper looking L brackets broke in half. Bracket has two smaller screws on each side to hold the frame to the windshield. Anyone source these L brackets locally or is it something I'll have to go back to FFR for?
    Nov 2018
    Centennial, CO
    Sorry to hear that. I can't help with that, but it does remind me that I am missing a chrome screw from the side of the windscreen frame. I hope those that know where you can get your bracket also know where one could get just one screw.
    Bradley
    Just heard the same story at the barn, other day. FFR does have the brass 90*s as he talked them into replacing his. I would try some sheet stainless and make it. The screws should be available at Ace or Lowes.
    McMaster-Carr has pretty much any nut, bolt, screw you could ever need. ID the style, size and thread pitch and I'll bet you can find it there. The only problem is you won't be able to buy just one.
    Senior Member frankb's Avatar
    Feb 2014
    Marana, AZ
    Albany County Fasteners (www.albanycountyfasteners.com) is another source that I use. They will sell you just one, but at an inflated price.
    Frank B
    Woodstock ,Illinois
    Are you talking about the screws that secure the side rails to the glass frame?
    North CT
    McMaster Carr screws
    I believe the 8mm length are the screws needed
    https://www.mcmaster.com/90258A318 8mm length
    https://www.mcmaster.com/90258A246 10mm length
    Nov 2018
    Centennial, CO
    Quote Originally Posted by steno View Post
    yes, that's it.
    Bradley
    Nov 2018
    Centennial, CO
    Thanks, looks like Mcmaster has them. I don't mind paying ten bucks to fix the problem, but 100 of them? Oh well, Ace would charge me 3 bucks each so...
    Sorry for the hijacked thread. I like the idea of making your own bracket, though I wonder if it needs to be made of brass for a reason.
    Bradley
    You could make it from brass and probably be a better grade than what comes on the windshield.
    North CT
    cv2065's Avatar
    Quote Originally Posted by chmhasy View Post
    Perfect. Thanks for the replies guys! Not sure why they are brass...maybe cheaper?
    North CT
    Those are not L brackets they are for the frame to the post they replace the brass strips
    cv2065's Avatar
    I see that. As long as they marry up with the holes in the frame, then they should be good to go.
    Fairfax Station VA
    I often get onesie-twosie quantities of hardware at https://www.boltdepot.com. Prices are very reasonable, and with a small order arrive quickly via USPS.
    MK IV Roadster #8631
  16. Thanks jrcuz thanked for this post
  17. #16
    Nov 2018
    Centennial, CO
    That looks like it might be handy!
    Bradley
  18. #17
    I think the brass is just an inexpensive way to avoid rust. SS would obviously work but it is more difficult to machine.
  19. #18
    cv2065's Avatar
    As an FYI, FFR doesn’t have these brass brackets. Said they were working with the vendor but no ETA on availability. I have some of those from McMaster Carr ordered.
