Thread: doors ??
    Senior Member jwhit's Avatar
    Oct 2019
    north carolina
    doors ??
    after cutting the huge hole in door for frame to slide in ,i dont see any panel to cover this up.
    am i over looking somthing for do you just leave the large cut out?
    Nov 2019
    Jacksonville, Florida
    I'm very curious about the answers....hmmm
    Edmonton Alberta
    no covers and you really can't see it much either. You do see the cut outs for the door hinge in the body.
    David W
    Mkll 4874 built in 2004
    Oct 2019
    north carolina
    Quote Originally Posted by David Williamson View Post
    David W
    ok thanks
    X2 on David W's answer. Cut the doors exactly like the Factory Five instructions show, and the frame will just tip through. The frame and hinges stick through it some, so it's not like the only thing you see there is a gaping hole. Agreed it's barely noticeable on the completed car. The hinge holes into the body are another story. Those are completely visible, and the dimensions from Factory Five are generous IMO. I took it very slowly and only made them as big as they needed to be. And leave the edges square and clean. Once painted will look OK.
    Gorham, ME
    I made an aluminum cover for both side, then painted them gloss black. This is on a Gen II though.
    Oct 2019
    north carolina
    Quote Originally Posted by John Dol View Post
    thats a option if im not happy how they look thanks for sharing
