5
83
I was looking at the rear trunk aluminum when I had the car on the front end rack and I noticed that the banana bar is rubbing on the trunk aluminum. Unfortunately I don't have a picture but I noticed on other build threads that there is a box in the trunk for the upper control arm clearance. The trunk aluminum I got does not have the cutout or the box. I am just wondering if anyone else had this problem with the 3 link rear setup. Thanks Ray
