![BluePrint Engines](https://www.factoryfive.com/wp-content/uploads/2015/12/BluePrint_Engines_Factory_Five_banner_ad_revised.gif)
Rear backing lights - Correct wiring connector?
So I'm hitting an issue. Before I call FFR (which I probably should do first, but anyway), are these the right connectors? My parts don't align. The wiring side has 3 holes in a row (- - -). The bulb has them offset (_ - _).
Am I using the right connector? I can't find anything different in a box or on the parts manifest.
20200214_122355.jpg 20200214_124157.jpg 20200214_122341.jpg 20200214_122326.jpg
I just bent them so they lined up and it works fine.
yes that are the right connectors for the rear backing lights.
They are not the best quality. One off mine came apart
Ok. Thank you. I'll just bend them and move on.
As always, I appreciate it.
