Thanks Thanks:  19
Likes Likes:  394
Page 8 of 12 FirstFirst ... 678910 ... LastLast
Results 281 to 320 of 457
Thread: Seths 33- 1133. Famous guy donut post.
  1. #281
    Senior Member sethmark's Avatar
    Virginia International Raceway
    Well I Successfully made my rear axle as expensive as it could’ve been had I just order direct from Moser... new gears, diff, brakes, shafts..... The nice thing is the car is smooth as a babies butt now.
    On another note I got around to spaghetti cutting the exhaust pipes.
    33 Hot Rod #1133. LS/TKO600
    Delivered 6-17-19. Started work 7-3-19. First start 9-6-19. First drive 9-24-19
    Titled 2-28-20
    MkI.IV 2643k
  2. #282
    Snuck the car up to a cars and coffee this am. Got a nice shot in the parking garage after....
    Titled 2-28-20
    MkI.IV 2643k
  3. #283
    May 2018
    Pinckney, MI
    Can you measure how long your lower control arm are? My top arm bracket sticks through th vertical panel and I needed a longer upper arm to get enough adjustment. Also my shocks are not as vertical. 75FCDC65-61CB-4A08-AF47-24AFBF1F4200.jpeg 13E2BFA8-1F65-4A04-95C1-5402C7CA62FD.jpeg thanks!
    Lower control arm center to center is 17.75.
    Upper arm for 3link about 17. I’ll need to adjust a bit.
    - Peterh226 #1134
  4. #284
    Sure! Lower links are 17.75”. Upper is 16.875. Pinion angle is 0. I’m in the lower hole for the lower links.
    Titled 2-28-20
    MkI.IV 2643k
  5. #285
    Well it’s official. The state of Virginia has issued title. One more hoop to jump through and they will hand me the title and I can go get plates. The last hoop is Vin verification. Should be a rubberstamp. I hope to pick my kid up from school in this car next week.
    Titled 2-28-20
    MkI.IV 2643k
  6. #286
    Sep 2019
    Congrats! I hope to do the same next week.
  7. #287
    Jun 2018
    North Vancouver, BC, Canada
    Excellent, congrats Seth!
    Gen 1 '33 Hot Rod #1104
  8. #288
    Some trim details.....
    First, the stubs for the roll hoop need to be cut at an angle to fit under the waterfall. They were not cut at Factory Five. Waterfall will not fit snug without cutting it.
    Second, the bustle that sits on top of the body had to be shortened to fit flat as well. That required loosening up the vinyl cutting a half an inch off the bottom of the flange and re-gluing.
    The vertical portion of the bustle is loose in this picture. I haven’t glued it back yet. I need to make trim rings for the roll bar.
    Titled 2-28-20
    MkI.IV 2643k
  9. #289
    Sep 2019
    Houston, TX
    That is going to be one excited girl when she sees you in the school pick up line!
  10. #290
    Placitas, NM
    You should let her drive the '33 around the school parking lot.
  11. #291
    She can’t reach the pedals..... can’t start it without pushing in the clutch. So tough! Lol.
    Titled 2-28-20
    MkI.IV 2643k
  12. #292
    Jun 2018
    Interesting that the roll bar stubs need to be cut back, that is not a problem on my Gen 1. The waterfall actually fits not too bad, much better than I thought it was going to. Limiting factor is actually the chassis, it's sitting right up against the back cockpit metal and chassis cross bar.
  13. #293
    I get the sense that they figured it out right quick. Since I won’t drive the car without the rollbar it’s not the end of the world. But it’s another thing.
    Titled 2-28-20
    MkI.IV 2643k
  14. #294
    And that’s basically a wrap. I’ve done just about everything I can do prior to body and paint. I’m strongly considering farming it out. The mess isn’t my cupajoe. I may finish it myself. But not planning on it right now.
    Titled 2-28-20
    MkI.IV 2643k
  15. Likes shmelty, HVACMAN, JimLev liked this post
  16. #295
    Jun 2018
    Looks great Seth! Did you hold off on some aluminum panels? I was thinking of doing similar to yourself, finish off except the finer parts of body and certainly the paint. But then to get that done the body has to come off so things like the striker mount and such need to come off again. It's a pain if they're behind a riveted panel...
  17. #296
    Yes. I left off four of the aluminum panels figuring doors will need to be adjusted during the bodywork process.
    Titled 2-28-20
    MkI.IV 2643k
  18. Likes HVACMAN liked this post
  19. #297
    Vin verification is complete. Now I have to wait for the computer to update and I can plate it. Just in time for high 60s next week.
    Titled 2-28-20
    MkI.IV 2643k
  20. Likes AJT '33, FF33rod liked this post
  21. #298
    Sep 2019
    Congratulations !!! Bet you are going to have a bunch of fun soon!!!!
  22. #299
    Tuesday I’m hoping. With the family move I’ve wasted the whole winter.
    At least I found a spot for that FFR badge.
    Titled 2-28-20
    MkI.IV 2643k
  23. #300
    Day 1 plated —- picked the kid up at school, drove 60 miles and had a blast.
    Titled 2-28-20
    MkI.IV 2643k
  24. Likes FF33rod, shmelty, JimLev, AJT '33, HVACMAN, JOP33 liked this post
  25. #301
    Jan 2019
    Man, I bet that feels awesome!
  26. #302
    Member Mrallsport32's Avatar
    Aug 2017
    Cotati California
    Hey I really like the nice set up with the braided line from the master cylinders. It looks like -3 or -4. What parts did you use to convert the master cylinders from the rubber hose attachments to be able to screw on the braided lines. Thanks.
    Gen 2 chassis #1121 delivered 2-10-19. SBC 400 with FI Tech dual quad, 700R4 trans and IRS.
  27. Likes shmelty liked this post
  28. #303
    Give me a couple hours to dig out all the part numbers and I’ll get them for you.
    Quote Originally Posted by Mrallsport32 View Post
    Titled 2-28-20
    MkI.IV 2643k
  29. #304
    Aug 2017
    Cotati California
    No hurry, thank you
  30. #305
    EAR-961603ERL
    -3 TO 1/8 NPT STEEL ADAPTER
    RAM-78326
    TEFLON LINE 18
    WIL-220-13130
    INLET KIT
    Titled 2-28-20
    MkI.IV 2643k
  31. Thanks shmelty, Mrallsport32 thanked for this post
  32. #306
    Spent the entire day today quarantined to the 33. Ran it about 85 miles. Science museum, train station, Home Depot, Virginia international raceway, coffee, Virginia state inspection...
    CEF3DA8D-4515-4417-AFE3-B1369D27CCE0.jpgCA4E76C1-21A4-4376-AA8E-462AAF33B5AC.jpg18522A11-EA50-44CA-A7F2-C6EFAC9AC812.jpgF0480736-6C3B-410D-93A0-DCC22599EF1D.jpg149CB148-A3F9-43C3-95D4-ED862BA1C258.jpg
    Titled 2-28-20
    MkI.IV 2643k
  33. Likes HVACMAN, shmelty, JimLev, JOP33 liked this post
  34. #307
    Village Mills, Texas
    I start vacation tomorrow. I am going to self quarantine to the garage. lol
  35. Likes JOP33 liked this post
  36. #308
    The plate....
    Titled 2-28-20
    MkI.IV 2643k
  37. #309
    Checking in at 400 miles. Car is pretty well behaved. No issues other than it settled and needs another alignment.
    oh and the dumb computer for the engine is set to a speed limiter of 95! Wtf! Found that out the hard way.
    Titled 2-28-20
    MkI.IV 2643k
  38. Likes JOP33 liked this post
  39. #310
    Falmouth, MA
    Speed limiter? That's what you get with all that new fangled hardware. I'm going with 3 -2's on my old Buick nailhead. Top speed only limited by my big toe and b@$%s.
  40. Likes Salty Chief 35 liked this post
  41. #311
    Quote Originally Posted by cob427sc View Post
    I’m not much for car shows.
    Titled 2-28-20
    MkI.IV 2643k
  42. #312
    Still practicing that social distancing stuff. Today my daughter and I did a hot rod 100. Nothing like two hours of chatting with your 13-year-old. Can’t replace that.
    On the car front, it got 26 miles per gallon over the hundred miles today. Flipped over 500.
    Titled 2-28-20
    MkI.IV 2643k
  43. Likes FF33rod liked this post
  44. #313
    Sep 2019
    You are having way too much fun! I will get you the door attachment pictures soon! Sorry for the delay. Take care! Ray
  45. #314
    I am. The car as a conduit for activities. First build it, then go do stuff in it. Honestly, the last 5% just isn’t that important to me today. Come winter I’ll feel differently I’m sure.
    Titled 2-28-20
    MkI.IV 2643k
  46. Likes FF33rod liked this post
  47. #315
    Sep 2019
    After weeks of fitting the panels I think the mechanical part is easy compared to the body work. There is just no rigidity with the hood, side panels and trunk. Everything moves around. I have built numerous brackets trying to make it solid. The hood hinges are only attached to the grille frame so its really wobbly. I am going to build a few more brackets to stiffen them up. Honestly even after that a person will have to be careful opening and closing the hood and trunk after paint. The doors seem to be pretty solid however. I don't know if you intend to run the hood and side panels but trust me if I build another one I won't. The lower panels they supply are for the 33 grille so you have to cut them down and even then the fit is lousy at best. They should really make the right panels it would make it much easier. Enjoy Ray
  48. #316
    You’re so right.....the doors have taken literally days each to get just ok. So much time in the body...
    Titled 2-28-20
    MkI.IV 2643k
  49. #317
    Titled 2-28-20
    MkI.IV 2643k
  50. Likes FF33rod, Mrallsport32 liked this post
  51. #318
    700 miles under the belt. Ran the car up the lift to do a nut and bolt. Exhaust manifolds were LOOSE on the heads. Suspension was snug and looked great. No leaks, pulls or problems to report. Chassis is FILTHY. That's gonna be a joy to clean. Often.
    Titled 2-28-20
    MkI.IV 2643k
  52. Likes JOP33, FF33rod liked this post
  53. #319
    Jun 2018
    Get the toothbrush and q-tips out LOL Good catch on the manifolds
  54. #320
    There will be a day that that car is as perfect as it’s ever going to be. Then there will be all the other days.
    I still can’t believe it’s got 700 miles on it.
    Titled 2-28-20
    MkI.IV 2643k
  55. Likes FF33rod, JOP33, AJT '33 liked this post
