Has anyone assembled a 32 deluxe grill yet? I’m missing parts according to the POL, but it doesn’t appear that way in the manual. I’d like to see how it mounts and what mounts to it.
33 Hot Rod #1133. LS/TKO600
Titled 2-28-20
MkI.IV 2643k
To answer my own question, I spoke with factory five today and the 32 grill is totally different. There are a number of parts and components for assembling the grill and condenser that do not cross over. Considering that I apparently have one of the early ones, I will post as I assemble. Currently I’m missing a bunch of components.
Titled 2-28-20
MkI.IV 2643k
Installation pics...
‘Installing grill in frame... I prefer using a 3/8 belt sander to notch the holes than using a drill bit to hog out the holes.
Titled 2-28-20
MkI.IV 2643k
Condenser and radiator sandwich. Note the instructions don’t call out drilling the lower radiator holes yet....which you must do at the beginning of the project.
Titled 2-28-20
MkI.IV 2643k
All assembled loosely the first time.
Titled 2-28-20
MkI.IV 2643k
The stack....
Titled 2-28-20
MkI.IV 2643k
Go to Factoryfive.com/instructions. There is an update you can download for the 32 deluxe nose installation.
33 Hot Rod w/ deluxe 32 nose
350 SBC and 700r4 automatic, 8.8 rear with 3.55 gears
Order date:4/25/19, Deliver date 6/10/19
First run 10/6/2019, Go cart 11/3/2019
You didn't by chance weigh the new grill & radiator assembly? It appears to have a fiberglass shell that I expect is much lighter than the cast aluminum 33 style.
I didn’t, but I most certainly can. It does however have the condenser and fan attached. If you want something specific, ask me and I’ll be happy to get it for you.
Titled 2-28-20
MkI.IV 2643k
That's great! Just need the weight of the grill, shell, and empty radiator. The 33 style is a bit porky and shedding front end weight would be an advantage on my car.
Complete assembly is 39#. The grill and shell weigh about 5#. Grill is just chromed sheet metal....
Titled 2-28-20
MkI.IV 2643k
Thanks! Wow, surprised it weighs that much.
The bracket setup is fairly elaborate...
Titled 2-28-20
MkI.IV 2643k
90* elbow off the radiator. Between the Coilovers and Bent up a piece of stainless pipe and routed it to the water pump. Can’t find a good picture.
Titled 2-28-20
MkI.IV 2643k
This is early in the fab process.
Titled 2-28-20
MkI.IV 2643k
It wasn’t bad at all. I bought the stainless tubing from Summit with a handful of 45s and 90s. I used the corrugated to set up my angles, then transferred it to tubing.
Titled 2-28-20
MkI.IV 2643k
By the way, I had the horns where the lower connection was and pulled them. Where did you move the horns to?
Split collar on frame.
Titled 2-28-20
MkI.IV 2643k
brilliant solution. I like simple and removable.
the only thing i dont like about the radiator is no trans cooler. they sent me the radiator for the original grill and it had one built it. Oh well. more money for the speed shops I guess.
